tb screw
1992mx3
tb screw
Post by 1992mx3 »
I may have made my life miserable. while trying to find out why my car was sputtering i had messed with a few things one being the screw atop of my tb and now I don't know where it is supposed to be set to. Does anyone here know the factory setting for this? help please...
1992 MX-3 GS in work.
2006 speed6, Wife say's i can't work on it.
2004 GSX-R 1000 Mat Mladin Replica
2006 toyota tacoma
1995 MX-6 in pieces almost ready for the junk yard, To much body damage.
lakersfan1
Re: tb screw
Post by lakersfan1 »
There is no factory position for the screw. You screw it in or out until your idle is around 700 RPM. That's all it's for.
1992mx3
Re: tb screw
Post by 1992mx3 »
very good thanks alot.
2006 toyota tacoma
andy
Re: tb screw
Post by andy »
before messing with the idle you should always be in the diagnostic mode. That is, Jumpering the ten and grnd pin in the diagnostic black box.
That applies to the TPS and both idle control screws. If you don't use a jumper you will only wind up pulling your hairs out wondering whats going on.
I have read that 3 1/2 turns out after bottoming
that screw is the normal starting point.
Andy P. 93 GS
