MX-3 V6 Clutch master cylinder
Hi Fellow MX-3er's. Does the V6 model have a clutch master cylinder? If so, where is it located? I am having a problem with the clutch on my 92 GS V6. When I push in the clutch pedal, it makes sort of a high pitched squeaking sound and the revs drop, making the engine stall. When I'm driving it shifts fine, although I still hear the squeak when I get on the clutch pedal (I need to shift quickly to avoid stalling the engine) My question is, does the MX-3 have a clutch master cylinder? If so, could the fluid being low/ empty cause this problem? The clutch does not slip at all when I'm driving. Any help would be awesome.
Re: MX-3 V6 Clutch master cylinder
As far as I know the clutch uses the brake master cylinder.
Can't be.. if they had same master cylinder, your clutch and brakes would activate at the same time.. They need to have seperate master cylinder'sOriginally posted by Grants:
I believe they do however share a common FLUID Reservoir.. Perhaps that's what you meant to say? so check the brake fluid level to make sure that fluid's not low etc..
{sigh} Time to move on
Out with the old: Tropical Emerald MX-3 GSR (KL-DE)
In with the new: Phantom Blue Mazda3s GT
Whoops - thats what I meant!
There is a connection between the clutch and revs - the ECU receives a signal from the clutch switch. The same signal is generated when the gearshift is in neutral. Do you get the same stalling in neutral with the clutch not depressed?
No, it does not stall in neutral. It stalls only when I push the clutch pedal in. It shifts fine though when I'm moving (Not enough time inbetween shifts to stall motor). Maybe the clutch master cylinder is going bad.
Hard to understand how that could be the cause. If the clutch hydraulics (master or slave cylinder) were bad, you would have very difficult and noisy gear shifts - do you?Originally posted by E Jackson:
If I understand you correctly, you are stationary with the transmission in neutral and the engine running. You depress the clutch pedal and the engine dies - is that right?
- jpwmx3
It sounds like the switch behind the clutch pedal is defective.
1993 GS V6/402,000km http://images.cardomain.com/member_imag ... 290_18.jpg
My thought too, but I 'm not too sure which switch or what defect.Originally posted by jpwmx3:
There are two clutch switches: One puts ground on ECU pin R1 when the clutch is depressed, but so does the neutral switch, and that isn't giving the problem. The other switch is the starter interlock - it only gets volts when the key is turned to start. Maybe there's a short on the line from that switch, which is having the effect of killing the ignition or fuel.
We just recently had the exact same issue with our clutch - exact same symptoms, noise, etc.
It was (I believe) the pilot bearing. If you have been driving it like this for a while, you'll need to replace your clutch assembly completely, due to the damage that would have been done...don't ask how I know...
