klze with k8ecu
MI-Archangel
klze with k8ecu
im told my interals will fry by a local mechanic. is it safe to drive on it for like 2 weeks>?
- papa roached
Re: klze with k8ecu
its gonna run super rich, see if you can track down a MX-6 or Probe GT VAF, that will run decent from what im told
Silver_Wraith
Re: klze with k8ecu
I'm Currently Running an mx-6 ecu until corksport can send me my klze ecu. But The only thing that i've noticed is that the timing in lower rpm's isn't exact and can seem a bit sluggish at times but over all it works and i don't get that bad of gas mileage out of it.
Wha-hoooo!!!! its finally in pics to come soon. http://www.cardomain.com/memberpage/540890
killerpickle
Re: klze with k8ecu
which vaf are you using with the mx6 one? You have to use the 2.5 vaf. The 1.8 will throw codes and run like garbage.
Tom Alexander
bubbaflaat
Re: klze with k8ecu
I'm running a K8 ecu and a 2.5Ltr VAF, it runs alot better with that VAF than the K8 VAF. Lots better gas mileage and smoother running.
THIS USER HAS BEEN BANNED, DO NOT DEAL WITH HIM. - MX-3.com Admin
Silver_Wraith
Re: klze with k8ecu
I'm Still running the stock k8 vaf and i'm not throwing any codes no problems other than previously stated.
killerpickle
Re: klze with k8ecu
the mx6 ecu and the 1.8 vaf do not go well together, trust me
Tom Alexander
