Clutch Questions
MazdaMx3Driver
Clutch Questions
Post by MazdaMx3Driver »
Can the Clutch and flywheel from a 2.5 ltr probe/mx6 be used on the mx3? aftermarket wise...
Talon_66
Re: Clutch Questions
Post by Talon_66 »
Yes they are interchangeable, I believe the 2.5L Clutch and Flywheel are about 10mm larger in diameter, but they are interchangeable.
<small>[ April 15, 2004, 11:31 AM: Message edited by: Talon_66 ]</small>
06 Eclipse GT *Sold*
08 Evo X GSR *Current*
TsiMiata
Post by TsiMiata »
Just the clutch is bigger, the flywheel is the same diameter. You can use a 1.8 flywheel with a 2.5 clutch or a 1.8 clutch on a 2.5 flywheel(all though I don't see why you would). It all swaps around.
91 Eagle Talon Tsi AWD *RIP*
Talon_66
Post by Talon_66 »
If u go to the Auto parts store and ask for the Ford Probe clutch, u will more then likely pay a lot less.
papa roached
Post by papa roached »
not to mention a "free" upgrade
MazdaMx3Driver
well for the guy who said that it is cheaper for the probe clutch.. heh thats what my plan is.... the clutch/flywheel is about half the cost of the aftermarket mx-3 ones.. Cool that works out great.. saves me about 250 bones :) thanks fellas
Talon_66
Post by Talon_66 »
No problem. Good luck with the swap!
