will a straight neck TB fit the US millenia IM?
I just got a great deal on a us-spec millenia intake mani. The only thing is it did not come with the Throttle body. Will the straight neck TB off the klze fit my new intake?
Re: will a straight neck TB fit the US millenia IM?
wheres the deal from, becouse we like deals. I cant see why it wouldnt fit, I have used a klze throttle body from a straight neck on a 1.8 manifold and na 2.5 manifold and that works fine.
92 MX-3 GS 2.5 KLZE
14.385 @ 98.21
14.385 @ 98.21
it will bold on no problem, but because it has a smaller inner diamiter you will have less air flow and you will loose some H.P.<p>you could try the local pick a part wreckers for a TB from a 2.5 probe,626,Mx-6.
Yes, I AM a bastard
Yes, I AM a bastard
It didnt fit right on mine because of 1 the coolant line or 2 the TPS sensor is located on the opposite side. I cant remeber which reason though.
- Zoso124
No it won't fit, look in the V6 FAQ, I did a little write up a while back, though I never uploaded any pictures.
Mike Evans
Gone:
Gone:
Ok that was some good info. are the 2.5 and 2.3 millenia TB's the same part#? can I bore my k8 TB to 65mm? how much will that cost?
you might find the studs on the end of the inlet manifold the wrong length so at worst you will just have to swap them over as well & also make up a bracket to hold the throttle cable. Otherwise ok.
