need help
natedwag03
need help
Post by natedwag03 »
My RPM goes up and down, does anybody know why?
I just replace my water pump and timing belt i don't think that will effect it.
92 Mazda Mx-3 V6 GS
appe
Re: need help
Post by appe »
My RPM goes up and down too but not hole time...it stays 0,8 (about) or 1,3 (about)...
Why?
Angel
Mike 94PGT
Re: need help
Post by Mike 94PGT »
An idle that oscillates like this is a sign of air leaking past a closed throttle plate or a mis-adjusted throttle position sensor. <p>Have you cleaned the throttle body with carb cleaner recently? Have you played with the idle air screw? Is the throttle closing completely? Has the TPS been replaced or adjusted lately?
Mike<BR>94 PGT <A HREF="http://home.golden.net/~trinity" TARGET=_blank>Codes, Maint, MAF, PCMs etc...</A><BR>Supermoderator, mx6.com
natedwag03
Re: need help
I have touched it once the throttle position sensor, but it wasn't that bad after i try to adjust it, now is getting worse when is in Neutral. Do you know how to Adjust it? please let me know.<p>Thanx
92 Mazda Mx-3 V6 GS
natedwag03
Re: need help
92 Mazda Mx-3 V6 GS
Hy300
Re: need help
Post by Hy300 »
How about this, mine usually idles at 800rpm. Though, when I put it in gear and have the clutch disengaged it will slowly rise to 1500rpm then drop, quickly, back down to 800. This only happens with the clucth disengaged and in gear. Not just when the clutch is pushed in.
Hy300
Re: need help
Post by Hy300 »
TTT
natedwag03
Re: need help
Hey guys,<p>
I found out why my RPM goes up and down, it is a little screw on top of the throttle body that need be adjusted,
92 Mazda Mx-3 V6 GS
