Headers
Headers
I have tried to look this up but can not find any informative posts...<p>I have a KL-ZE and am completely reinstalling the entire exhaust. My question is: who makes headers for the 6 cyl? I have heard that no one does, and that people are modifying headers for the MX-6 instead. I would also like input on the size required for the exhaust itself as I am planning on supercharging the car within a year - 2.5" or 3"?<p>Thanks for any input!
Re: Headers
Try www.hksusa.com
In
Eunos 30x, v6
KL-ZE, 2.5in exhaust, K&N intake
Unichip, LSD, 13lb flywheel, ACT2 clutch, NGK iridium Plugs, Top Gun Leads...<p>Goin In
Cams, Headers, TB, Extractors,
Bored to 2.8, Mazdaspeed Struts, Mazdaspeed strut tops,
Mazdaspeed swaybars, Eibach springs, Cusco Adj. Strut tops, Body kit, Altezza lights, Short shifter, Crossdrilled rotors and Calipers from AP racing, Braided brake lines, Braided clutch line, Mazdaspeed steering wheel, Mazdaspeed Leather shift knob,
Eunos 30x, v6
Re: Headers
you can use the mx6 headers without any mods to the headers it's self.The muffler shop will just have to shorten your ehaust about six inches
MY ZE is on the Bottle how about yours?
The offical PUnK a-- RaCeR of MX-WEST
Re: Headers
hey David... where on HKS did you find anything regarding headers for either the MX-3 or the MX-6? I found the site to be informative with the Q & A's but not helpful with regards to finding what I need.
Re: Headers
Hey there... The HOTSHOT header are a direct fit to the motor. You will have to have a muffler shop do some slight modifing to them. The reason being that the HOTSHOT headers come with a O2 sensor port in front header and a EGR port in rear header. Since the Mx-3 has 2 O2 sensors you need to add one. I also have the KLZE so I don't use the EGR system, so I removed the EGR port. The muffler shop charged me $10 to do these modifications. After that you will have to have custom pipes from the down pipe off the headers back. So you cat will have to be moved alittle. Not hard for any good muffler shop to do all this.. It cost me $200 for a new cat and new custom exhaust all the back... Headers cost $450 and MY muffler was $200.. Total spent was about $850 total I think.. Hmm now that I think of it thats alot hehe...
Re: Headers
as for exhaust pipe size...most dsm guys run 3" turbo back....and it is probably recommended...however, i personally am running 2.5" pacesetter piping, and my dynos are not showing signs that its a restriction yet....but i will probably replace that with a full 3" in the future...<p>btw, im also running hotshot headers (just the primaries) and its on a stock KL03 motor<p>[ February 06, 2003: Message edited by: Rayman ]</p>
95 Ford Probe GT | 03 Dodge Ram 1500 ST | 71 Ford Mustang "Mach I" clone | 90 Mazda 323 | 00 Yamaha YZF-R6 | 2003 Kawasaki Z1000
Re: Headers
get either bro speed or hot shot
- Custommx3
- Site Administrator
Re: Headers
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by davidosk024:
Try www.hksusa.com<hr></blockquote><p>I think the only ones that are made as I have seen are Bosal and Hotshot. I think Pacesetter had a set, but that im not 100% sure about. I know the Hotshot will fit, We put it on k8 engine I had im my garage, fit fine as far as to the motor. Its the same on all K series blocks.
Orange GSR is correct, a few ppl have them already.
Re: Headers
This SO has nothing to do with forced induction.<p>Moved to V6 performance.
David Coleman
- Buff1110
Re: Headers
pacesetter does make a set
there on carparts.com
the black ones are only $210 and the heat treated ones are like $270
there made for the pgt and mx6 so just like all the other headers, your cat will have to be moved back to make it all fit.
Dan
02 Tacoma TRD - Daily
Re: Headers
HMM<p>they used to have headers on there for the mx-6...
was awhile ago. <p>Ill call around here and ask to see if they still stock them at some of the dealers here
In
Eunos 30x, v6
Eunos 30x, v6
