Belt Problems
Belt Problems
I have a question. When I start my engine my belts squeel. I figure I just need a new belt or some belt conditioner. BUT they squeel every time I get on the gas from idle. Even when I slow down from high speeds to idle it will squeek a little. Is this normal for a worn belt to do? I'm a little worried that maybe one of my pulleys may have either seized or have some resistance. Please help. thanks.
~Ryan~
1994 MX-3 GS Teal
1987 Toyota Pickup
SR5 Xtracab Turbo
1994 MX-3 GS Teal
1987 Toyota Pickup
SR5 Xtracab Turbo
Re: Belt Problems
Mine does the same but only on startup. I got rid of it by adjusting the tensioners to tighten the belts. It last about a week and then started to come back. Someone suggested to change the belts but mine are only a year old. I know mine is the A/c belt and I will get under there again sometime and tighten it more. If that doesn't work then I guess I need new belts. hope that helps a bit.
Re: Belt Problems
Tighten them with a 10mm wrench, according to the manual. [img]shrug.gif"%20border="0[/img]
David Coleman
Re: Belt Problems
Most people have told me to tighten the belts. As soon as I get a little breathing time I will get under there and do that. Thanks for your replies.
~Ryan~
1994 MX-3 GS Teal
1987 Toyota Pickup
SR5 Xtracab Turbo
1994 MX-3 GS Teal
1987 Toyota Pickup
SR5 Xtracab Turbo
- Buff1110
Re: Belt Problems
i actually solved my problem with the belts squeeking by purchasing oem belts from mazda. the oem ones are thicker and i havent had any problems since. before the mazda belts i went through 3 different sets.<BR>Dan
Dan
02 Tacoma TRD - Daily
yea I have that squeeking problem right now and my belts r brand new. it started out it would just squeek a lil on start up, the i tightened it and it went away. once the cold weather rolled in it squeeks alot now. I have loosened it- tightened it, n called it all kinds of names. Dont ever buy gator belts im gonna say get the mazda belt because everyone seems to have great luck with mazda belts....
Teal 1993 MX3GSZE
did we need to resurect a 6 year old post? Ryan isnt even on the board anymore lol
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
Belt Problems
I had this on as well - turned out to be 'inferior' quality belts, plus tension.
