Flywheel Machining
SimonPK
Flywheel Machining
Post by SimonPK »
My local Mazda dealer is saying when I change the clutch I need to have the flywheel machined for about C$100. Because it will have heat spots after being used for 175,000kms. Is this true?<P>If I do the clutch myself to save $600 in labour do I have to get the flywheel done?<P>Thanks
David Coleman
Re: Flywheel Machining
Post by David Coleman »
You should be able to take the flywheel to any machine shop that can turn brake rotors to be turned. Should cost about 20USD.
David Coleman
Zoso124
Post by Zoso124 »
Or you could always order one at Autozone for $50.
Mike Evans
Gone:
SimonPK
Post by SimonPK »
I still can't figure out why though? Does it distort or get high spots or does it case harden or something?!
chance
Post by chance »
you want the surface to be nice and smooth to break in your new cluch. and hey, look at it this way, if you get it machined it will be lighter
David Coleman
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Si:<BR><STRONG>I still can't figure out why though? Does it distort or get high spots or does it case harden or something?!</STRONG><HR></BLOCKQUOTE><P><BR>For the same reason you machine brake rotors: you want a straight, true surface.
David Coleman
