Spark Plugs
Spark Plugs
so i got bosch platinums and im not sure if i got the spacing right does anyone know what the spacing is soposed to be? and also i talked to some one else and they said they had it as well, i feel a lag on almost every gear untill 3000 rpms, is this normal, i didnt notice it till now
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
Re: Spark Plugs
also i put a new catalytic converter on about 2 weeks ago and the car has also seemed to of gotten a bit louder could i be loosing back pressure? and if so how could i correct this problem?
Re: Spark Plugs
You can usually find the information about the spark plug gap on a label under the front hood. Platinum spark plugs don't work well in our cars. I don't have a good explanation for that other than hearing testamonials on the probetalk site and the other mx-3 group. I also tried platinums when the car was newer and didn't like the way the motor performed. I'm sure theres a good technical reason out there somewhere.<BR> It could just be that the new plugs are making an existing condition more noticable.<BR> My car always seems to lag until the first vris plate opens at about 3200 rpm's. [img]shrug.gif"%20border="0[/img] <P>Andy P. 93 GS
Re: Spark Plugs
Thanks man i popped the hood and there it was went and fixed the problem, runs good now, and i also found out the reason it is louder now it my new cat is allowing it to flow better which is causing me to sound like a bumble beeeeeeeeeeeeeeeeeeeee
Re: Spark Plugs
If platinum plugs aren't supposed to do well in our cars, what works the best?
Re: Spark Plugs
platinum plugs last longer, no nitrous on them though!
93 Mx-3 GS klze swapped(sold)
96 Integra LS DD
91 Crx Si drag car
2.0L sleeved gsr block, forged internals, skunk2 valvetrain, HP racing intake manifold, Holset H1 turbo, 1000cc injectors, short geared lsd transmission, 3" turboback exhaust. 20 psi![Smile :)](./images/smilies/icon_smile.gif)
96 Integra LS DD
91 Crx Si drag car
Re: Spark Plugs
i herd not to get platinum 4s cause they cause your hp to drop but u get way better gas mileage
- Buff1110
Re: Spark Plugs
copper plugs work the best, i prefer ngk myself.<BR>Dan
Dan
02 Tacoma TRD - Daily
Re: Spark Plugs
What high flow cat did you get and where?
Re: Spark Plugs
they took my car to midas and they put the new cat on i havent checked to see what it was yet
Re: Spark Plugs
I use Bosch Platinum2. They work really good and I have them in the cars my family owns.
Re: Spark Plugs
I always hear ngk tr-55. i think that's what they're called
Cam
Teal 1992 MX-3 5-spd
:1.8liters of V6 fury, 2 shiny tips:
:for sale:
MazdaSpeed?
:for sale:
MazdaSpeed?
