KLZE.... Where to buy?
Where is the best place to buy a KLZE with all the parts required to install?<P>Corksport has them for $1800 with ECU<P>Where else?
Re: KLZE.... Where to buy?
<A HREF="http://www.sunsengines.com," TARGET=_blank>www.sunsengines.com,</A> if you say you are a probetalk member they sell em for $950+shipping, or swapjdm.com sells the engine+tranny+shipping for $1299, streetimports.com sells for $1299+shipping, noyanusa sells em for $1150+shipping, there's tons of places if you have a gs model you have everything you need, you need a curved neck intake manifold, you need to swap the water inlets cause the 92-93 has the fan water sensor in the inlet or tap another one, yet another victim of the not so search button
<p>[ September 21, 2002: Message edited by: lazzyie ]
93 Mx-3 GS klze swapped(sold)
96 Integra LS DD
91 Crx Si drag car
96 Integra LS DD
91 Crx Si drag car
Guest
try <A HREF="http://www.a1jdmengines.com" TARGET=_blank>www.a1jdmengines.com</A> tell um pawz sent u!
I know about the search engine, however I didn't find alot of people agreeing on ONE place that is VERY good about getting you the right stuff, on time, and good quality. This is what I was really asking.. :p <P>My thing is I am good at following instructions, but I have never done a import engine swap. The only swap I have done is a 1950 Chevy pickup 216 motor to a 235 motor. I just wanna make sure I get everything I need to do this job all from the same place. My 93 GS is a manual. Will I need the transmission to? I have read alot don't get me wrong but am still alittle confused.. How hard is this to do in you garage at home? From what I read this should just be as easy as unplug and pull and install and replug. Am I missing something here?
pelado
Yes, you can do this. It was my first import swap also. Check out the V6 FAQs. Check out the mx-3.com swap pages. Label everything. Take photos. You can use the MX-3 trans and flywheel.<P>You could have found many questions just like yours by searching. Search for threads with "KLZE" in title. Just kidding. Look for "KLZE install" or "KLZE swap."
I got mine from swapjdm.com, i have had no problems with it thus far, knock on wood, I would have gone with sunsengines.com had i known about them because its a 6 month unlimited mile warranty, its all kinda of hit and miss with the engines, the swap is pretty easy though just time consuming and a lot less room than you would like! good luck!
96 Integra LS DD
91 Crx Si drag car
96 Integra LS DD
91 Crx Si drag car
Did the <A HREF="http://www.sunsengines.com" TARGET=_blank>www.sunsengines.com</A> page change? It will not pull up for me.
Putter...Putter...Putter...
The Unstoppable MX-3 GS
93mx3gs
Lazzyie accidentally put a "," at the end of the link...the one you just posted will work
ghandi1981
i got mine from suns engines...they are super friendly and very helpful and it only cost my $1117 ($950 + $167 shipping from california to south tx)...i should be getting the engine this friday (9/27) so i'll tell yall guys the condition of it....<P>AJ
resurected KL-ZE,ZE ECU, 9lb Fidanza Flywheel, CMIII, home depot CAI, Hiflow Cat, 2 1/2" piping, exhaust, 2 MASS 2012's, Cadence A7, Blaupunkt Casablanca, and a no damn CEL light!!!
Anyone else get one from sunsengines.com?
David Coleman
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Dj_Pawz_GS:<BR><STRONG>try <A HREF="http://www.a1jdmengines.com" TARGET=_blank>www.a1jdmengines.com</A> tell um pawz sent u!</STRONG><HR></BLOCKQUOTE><P>heh, if you don't want a real ZE anyways :p<P>I got mine from <A HREF="http://www.noyanusa.com" TARGET=_blank>www.noyanusa.com</A> . Several PGT guys have gotten theirs from there, and have had the same quality engines that I have. 1197USD to my door with liftgate fee.
David Coleman
David Coleman
Searching on google.com resulted in: <A HREF="http://www.nippon-motors.com/prices.htm" TARGET=_blank>http://www.nippon-motors.com/prices.htm</A> <A HREF="http://www.wcperformance.com/jdm_motors.htm" TARGET=_blank>http://www.wcperformance.com/jdm_motors.htm</A> <P><BR>Also, Sean Matthews at <A HREF="http://www.streetimports.com" TARGET=_blank>www.streetimports.com</A> is one of the old school MX-3 guys. He's done several of these swaps personally, and knows what you need and has great prices. I'd definately order from him if I had to do it over again.
David Coleman
So the sunsengines are not real KLZE's?<P>I talked to PROTECH again today... They offered to install the KL-03 Engine(KLZE right?) for $2100. This included the engine and all parts needed for the install... I am not sure if they know that the intake won't fit. I read that the Milliena(spelling?) intake will work to fix this though? But will this intake fit under my strut tower bar?
ghandi1981
my engine came in today
too bad i am an hour away from it at school....when i get back home i need to get my car towed to the shop and ill see what shape my motor is in....also what is a quick way to make sure it is a ze without taking it apart...just in case
...damn now i need to clean my car and put the spare tire on it...hehe<P>AJ
