KLZE.... Where to buy?
Where is the best place to buy a KLZE with all the parts required to install?<P>Corksport has them for $1800 with ECU<P>Where else?
Re: KLZE.... Where to buy?
<A HREF="http://www.sunsengines.com," TARGET=_blank>www.sunsengines.com,</A> if you say you are a probetalk member they sell em for $950+shipping, or swapjdm.com sells the engine+tranny+shipping for $1299, streetimports.com sells for $1299+shipping, noyanusa sells em for $1150+shipping, there's tons of places if you have a gs model you have everything you need, you need a curved neck intake manifold, you need to swap the water inlets cause the 92-93 has the fan water sensor in the inlet or tap another one, yet another victim of the not so search button
<p>[ September 21, 2002: Message edited by: lazzyie ]
![Image](http://probesport.extremespace.com/iB_html/non-cgi/emoticons/chairshot.gif)
93 Mx-3 GS klze swapped(sold)
96 Integra LS DD
91 Crx Si drag car
2.0L sleeved gsr block, forged internals, skunk2 valvetrain, HP racing intake manifold, Holset H1 turbo, 1000cc injectors, short geared lsd transmission, 3" turboback exhaust. 20 psi![Smile :)](./images/smilies/icon_smile.gif)
96 Integra LS DD
91 Crx Si drag car
try <A HREF="http://www.a1jdmengines.com" TARGET=_blank>www.a1jdmengines.com</A> tell um pawz sent u!
I know about the search engine, however I didn't find alot of people agreeing on ONE place that is VERY good about getting you the right stuff, on time, and good quality. This is what I was really asking.. :p <P>My thing is I am good at following instructions, but I have never done a import engine swap. The only swap I have done is a 1950 Chevy pickup 216 motor to a 235 motor. I just wanna make sure I get everything I need to do this job all from the same place. My 93 GS is a manual. Will I need the transmission to? I have read alot don't get me wrong but am still alittle confused.. How hard is this to do in you garage at home? From what I read this should just be as easy as unplug and pull and install and replug. Am I missing something here?
Yes, you can do this. It was my first import swap also. Check out the V6 FAQs. Check out the mx-3.com swap pages. Label everything. Take photos. You can use the MX-3 trans and flywheel.<P>You could have found many questions just like yours by searching. Search for threads with "KLZE" in title. Just kidding. Look for "KLZE install" or "KLZE swap."
I got mine from swapjdm.com, i have had no problems with it thus far, knock on wood, I would have gone with sunsengines.com had i known about them because its a 6 month unlimited mile warranty, its all kinda of hit and miss with the engines, the swap is pretty easy though just time consuming and a lot less room than you would like! good luck!
96 Integra LS DD
91 Crx Si drag car
96 Integra LS DD
91 Crx Si drag car
Did the <A HREF="http://www.sunsengines.com" TARGET=_blank>www.sunsengines.com</A> page change? It will not pull up for me.
Putter...Putter...Putter...
The Unstoppable MX-3 GS
Lazzyie accidentally put a "," at the end of the link...the one you just posted will work
i got mine from suns engines...they are super friendly and very helpful and it only cost my $1117 ($950 + $167 shipping from california to south tx)...i should be getting the engine this friday (9/27) so i'll tell yall guys the condition of it....<P>AJ
resurected KL-ZE,ZE ECU, 9lb Fidanza Flywheel, CMIII, home depot CAI, Hiflow Cat, 2 1/2" piping, exhaust, 2 MASS 2012's, Cadence A7, Blaupunkt Casablanca, and a no damn CEL light!!!
Anyone else get one from sunsengines.com?
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Dj_Pawz_GS:<BR><STRONG>try <A HREF="http://www.a1jdmengines.com" TARGET=_blank>www.a1jdmengines.com</A> tell um pawz sent u!</STRONG><HR></BLOCKQUOTE><P>heh, if you don't want a real ZE anyways :p<P>I got mine from <A HREF="http://www.noyanusa.com" TARGET=_blank>www.noyanusa.com</A> . Several PGT guys have gotten theirs from there, and have had the same quality engines that I have. 1197USD to my door with liftgate fee.
David Coleman
Searching on google.com resulted in: <A HREF="http://www.nippon-motors.com/prices.htm" TARGET=_blank>http://www.nippon-motors.com/prices.htm</A> <A HREF="http://www.wcperformance.com/jdm_motors.htm" TARGET=_blank>http://www.wcperformance.com/jdm_motors.htm</A> <P><BR>Also, Sean Matthews at <A HREF="http://www.streetimports.com" TARGET=_blank>www.streetimports.com</A> is one of the old school MX-3 guys. He's done several of these swaps personally, and knows what you need and has great prices. I'd definately order from him if I had to do it over again.
David Coleman
So the sunsengines are not real KLZE's?<P>I talked to PROTECH again today... They offered to install the KL-03 Engine(KLZE right?) for $2100. This included the engine and all parts needed for the install... I am not sure if they know that the intake won't fit. I read that the Milliena(spelling?) intake will work to fix this though? But will this intake fit under my strut tower bar?
my engine came in today
too bad i am an hour away from it at school....when i get back home i need to get my car towed to the shop and ill see what shape my motor is in....also what is a quick way to make sure it is a ze without taking it apart...just in case
...damn now i need to clean my car and put the spare tire on it...hehe<P>AJ
