Anti-freeze
Anti-freeze
Is there a compatibility issue with some types of anti-freeze and water pump seals?<P>Water pump seal on my ZE went out within less than three months after the swap. I thought I might have tightened the drive belt too much but when I removed the leaky bastard there was no wobble at all to the shaft.<P>I'd like to ensure this won't happen again during my lifetime so if any of have any hints on how to make water pumps last, I'm all eyes!
Re: Anti-freeze
hmmm water pump should last very long time, the type of antifreeze you must use is ethylene-glycol based, hit the 50/50 with water and all should be good, or maybe ya didn't put the seal on right? Maybe the car dislikes you! Sorry man hope you have better luck!
93 Mx-3 GS klze swapped(sold)
96 Integra LS DD
91 Crx Si drag car
96 Integra LS DD
91 Crx Si drag car
Re: Anti-freeze
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by lazzyie:<BR><STRONG>hmmm water pump should last very long time, the type of antifreeze you must use is ethylene-glycol based, hit the 50/50 with water and all should be good, or maybe ya didn't put the seal on right? Maybe the car dislikes you! Sorry man hope you have better luck!</STRONG><HR></BLOCKQUOTE><P>Thanks for the reply, but the water pump seal is on the shaft of the pump and I didn't touch it. <P>The anti'freeze I used was some of that environmentally and non-toxic to animals kinda stuff, the brand name is Sierra.
Re: Anti-freeze
Did you install a new or rebuilt pump?<BR> I don't know about the enviro friendly anti-freeze because I have never tried it.<BR> In the end, it sucks, hopefully you can at least get another pump under warranty.<BR> I know when I bought a replacement pump they had a rebuilt unit or a new one and I opted for the new one.<BR> better luck on the next pump.<P> Andy P.93 GS
- Zoso124
Re: Anti-freeze
From what I know only certain GM motors must have DEX-COOL approved coolant in them. Its also suppose to have an extended life, and its Orange not Green.
Mike Evans
Gone:
Gone:
