What's your temperature gauge read?
zytariuk
The needle sits at about 1mm above the half way mark (60%). <P>- Is this normal for a 92' GS? <BR>- What about you guys? Where does your needle sit?
aaronthehic
Re: What's your temperature gauge read?
ditto
93 Mx-3 GS klze swapped(sold)
96 Integra LS DD
91 Crx Si drag car
96 Integra LS DD
91 Crx Si drag car
Mine has always sat a little below half way, a guess that makes it about 40%, except tor the time when the water pump went south. After a new pump and timing belt it returned to 40%.<BR> Andy P. 93 GS
Mine reads about 1mm below the half-way mark. That's in a GS in Florida.<P>Sure wish I had a oil pressure guage so we could swap our oil pressures as well. Has anyone added a oil pressure guage? How hard is it?
David Coleman
Mine with the K8 and KLZE is at 1mm below the middle, around 45% of the the gauge's sweep.
David Coleman
mine is about 60% too and i have 92 gs
mine reads under half about the same distance as the other guys who report under half.
Mine is just a little bit higher than the middle.
back alley
92gs in western canada, needle sits exactly at half, summer or winter
mine sits at a little bit below middle all the time i could drive it hard all day no change 92 rs i have a K&N and a better intake and the big open area on my fx bumper might help
nicolasbeique
about 60% like alot of people said... does anyone know if that "Redline Water Wetter" stuff that's suppose to cool down your intercooler works?
<A HREF="http://www.spheregraphics.com/" TARGET=_blank>
</A>
</A>-
pelado
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Nic Beique:<BR><STRONG>about 60% like alot of people said... does anyone know if that "Redline Water Wetter" stuff that's suppose to cool down your intercooler works?</STRONG><HR></BLOCKQUOTE><P>I bought some but I never used it after reading on another site that it was just a modern version of snake oil.<p>[ August 30, 2002: Message edited by: pelado ]
I used it in my CRX and it did decrease the temperature just a bit. You have to use distilled water with it though.
