What's your temperature gauge read?
The needle sits at about 1mm above the half way mark (60%). <P>- Is this normal for a 92' GS? <BR>- What about you guys? Where does your needle sit?
<img src="http://members.rogers.com/zytariuk/images/mx-3.gif" alt=" - " />
1992 Mazda Mx-3 GS - Beige metallic
zytariuk's mx-3 page (updated June 12th, 2003)
Re: What's your temperature gauge read?
ditto
93 Mx-3 GS klze swapped(sold)
96 Integra LS DD
91 Crx Si drag car
2.0L sleeved gsr block, forged internals, skunk2 valvetrain, HP racing intake manifold, Holset H1 turbo, 1000cc injectors, short geared lsd transmission, 3" turboback exhaust. 20 psi![Smile :)](./images/smilies/icon_smile.gif)
96 Integra LS DD
91 Crx Si drag car
Mine has always sat a little below half way, a guess that makes it about 40%, except tor the time when the water pump went south. After a new pump and timing belt it returned to 40%.<BR> Andy P. 93 GS
Mine reads about 1mm below the half-way mark. That's in a GS in Florida.<P>Sure wish I had a oil pressure guage so we could swap our oil pressures as well. Has anyone added a oil pressure guage? How hard is it?
Mine with the K8 and KLZE is at 1mm below the middle, around 45% of the the gauge's sweep.
David Coleman
mine is about 60% too and i have 92 gs
mine reads under half about the same distance as the other guys who report under half.
Mine is just a little bit higher than the middle.
92gs in western canada, needle sits exactly at half, summer or winter
mine sits at a little bit below middle all the time i could drive it hard all day no change 92 rs i have a K&N and a better intake and the big open area on my fx bumper might help
about 60% like alot of people said... does anyone know if that "Redline Water Wetter" stuff that's suppose to cool down your intercooler works?
<A HREF="http://www.spheregraphics.com/" TARGET=_blank>
</A>
![Image](http://www.spheregraphics.com/SG_BannerProfile1a.jpg)
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Nic Beique:<BR><STRONG>about 60% like alot of people said... does anyone know if that "Redline Water Wetter" stuff that's suppose to cool down your intercooler works?</STRONG><HR></BLOCKQUOTE><P>I bought some but I never used it after reading on another site that it was just a modern version of snake oil.<p>[ August 30, 2002: Message edited by: pelado ]
I used it in my CRX and it did decrease the temperature just a bit. You have to use distilled water with it though.
