need more horsepower
Smokin mx-3
I have a kl-ze in 92 mx-3 gs and I'm looking for more power <BR>I was wondering if I bought a clutchmaster stage 3 clutch would that put more power to the ground <BR>any upgrades would be helpful<BR>thanks
Re: need more horsepower
um, a clutch won't actually GIVE you power, just let your tranny hook up better under massive loads. if your clutch is slipping then yeah, it'll make you quicker, but only b/c you are launching better. i'd suggest a lightened flywheel, pulleys, CAI, maybe exhaust/cat/strightpipe (depends on if you have to pass emissions). you may also want to look into phenolic spacers and the throttle body coolant bypass mod (search David Coleman's entries). are you running your 1.8L ecu? if you are, you may want to look for one from a ZE. my 2 cents.
Dude.
white fish
wider, better tires will help you get the power to the ground
93mxrgs
io have a stage 2, and its almost 2 stiff for the street, but with a ze i would say a stage 3 would be just the ticket, i bought mine cause i was planning on doin the swap, and i needed a new clutch at the time, so i went with a good one
Black-93 mx-3 Gs-R<BR>with goodies
<BR>Hondas suck, and yes i race them...<BR>oops i mean no no i dont
ProtegeSTS
OsoSlo z28
oh come on, you can do better than that. let's try it again...."T-W-I-N T-U-R-B-O".
"MR." Ashley Fowler
'02 Yamaha Warrior (1700cc)
'94 MX-3 RS-t (BPT)~ sold
cardomain pics
"MR." Ashley Fowler
cardomain pics
I thought that you shouldn't turbocharge the KL_ZE because of the compression ratio.
~Ryan~
1994 MX-3 GS Teal
1987 Toyota Pickup
SR5 Xtracab Turbo
1994 MX-3 GS Teal
1987 Toyota Pickup
SR5 Xtracab Turbo
OsoSlo z28
you can still turbo, but your boost is limited unless you can really customize your air/fuel ratio along with running higher octane to prevent detonation
"MR." Ashley Fowler
cardomain pics
"MR." Ashley Fowler
cardomain pics
stevwhit17
You can turbo or sc the ZE if you want to run less than 7 psi. Im sure thats pretty safe for them. I think Darin Pemberton on Probetalk is running like 8 psi on a KL03. <P>Hey man if you want more power, a good ZEX nitrous kit will give you more than enough, just be careful. You already have a lot of power, I dont see why you would want more unless tou are a competetive drag racer or something. I am fairly happy with my 150+ hp in my Neon. Of course I want boost, but Im just looking realistic.<P>For smaller adders, go for some i/h/e, lightened flywheel. UDP, ported&polished TB. Theres all sorts of stuff. If you add them all at once you will notice a pretty big difference. If you add them one by one you will only see the results at the track. Good luck.
98 Neon R/T - Iceman/K&N, Clear corners, Painted calipers, ceramic brakes, PIAA lights. New head gasket
