Two amps
Two amps
I have a mono amp powering my sub and my 6 1/2s are running off my head unit. I'm thinking of using a little 4 channel amp to power the 6 1/2s but I've been told that using two amps would kill my battery quick. Can you experts out there shed some light on this matter?<p>Thanks,<p>Oh yeah, the mono amp is 300w and the little 4 channel is 220w.
- airjordon_09
Re: Two amps
buy another battery, they are only like $50 and its worth it just so you dont have to take that risk of screwing up your only battery <p> peace
Re: Two amps
where would you put a 2nd battery? Im thinking about one but i have no idea on where to hide it, and i dont wanna get one too comphy under the hood for if and when i go a 2.5l swap
Re: Two amps
i'm running 4 amps and im using a two year old die hard battery. Unless you plan on playing music for hours on end with your car off two amps would be just fine. Even if you do play your music with the car off, buy an optima yellow top.
Shaun Newman
- 2fazed
Re: Two amps
Campacitor, 1-farad per 1,000 watts. I had three amps with the stock battery. The aircondition is the only thing that would effect it.
06 Mazdaspeed6 2.3T
93 626 ES 2.5
92 Mx-3 RS 1.6
93 Mx-3 GS 2.5
93 Mx-3 RS 1.6
06 Mazdaspeed6 2.3T
93 626 ES 2.5
92 Mx-3 RS 1.6
93 Mx-3 GS 2.5
93 Mx-3 RS 1.6
Re: Two amps
I ran/run just one amp and i get TONS of dimage. Its not the number of amps, its the size of the amp(s). Look at the current draw...<p>114amp draw used to dim me a lil. I don't have the specs on the MMATS amp to tell me how much more current draw it was, but it made me dim a lot.<p>It also depends on your car. Sometimes your electrical system can go bad before others do. And vise versa.
FOR SALE, AS A PARTS CAR
- monty73741
Re: Two amps
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=1498&item=3000177209<p>use that if you have any battery wories
jason
jason
Jason Danaher
Please Help Support MX-3.com
Re: Two amps
i had 140a draw on a stock alt for the 1.6 and the lights dimmed like crazy but i just put a 220a alt on my gs and my draw will now be about 180 so ill see how it is.
Re: Two amps
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by monty73741:
jason<hr></blockquote><p>yep, 170ma will sure help you [/sarcasm] !<p>if you read the auction, that is for ppl who are leaving their car to sit for months/years, but need their computers to have power.... or something like that.
"to accomplish it’s original purpose – keeping the 12volt battery fresh and ready for use even after long idle periods"
- monty73741
Re: Two amps
I KNOW I KNOW it was a little sarcasm<p>json
Jason Danaher
Re: Two amps
Basically the battery is more or less to just start the car, after that most of the load in on your alt, or should be. The best thing would be a better alt and update the wiring under the hood a little.
Re: Two amps
i will have to disigree with u on that one. the battery gets all the load even when the car is running the alt just charges it. i have a 220A alt but i have a cheap battery so when i turn my stuff up the lights still dim like crazy because the batt can't charge as fast as the amp is pulling it. so with a bigger bat and or capacitor/s it should solve the problem.
