Engine not starting!
Hey, all, just done the swap to BPT but i have incounter problems. The engine won't start for some reasons. The starter works cause the engine is turning over but it will not fire. Just wondering, normally when u turn the key on you can hear the fuel pump buzzing and now it makes no noise. I suspect the fuel pump is not working. Do you have to changed any wire with the conversion? and does the mx-3 fuel pump able to supposrt the bpt?
- ryanlindenberg
Re: Engine not starting!
what kind of engine management are you running? if you aren't using the OEM ECU then your fuel pump won't work. and no the mx-3 fuel pump doesn't have the capacity to handle the bpt. i used this pump, pretty much a direct swap. part #FPM204.
AUTO PERMANCE ENGINEERING
you will still need to buy the seal for the tank for an mx-3 though.
CARDOMAIN WITH UPDATED PICS
it would at least be able to start the car. since you used the bpt ecu, check the pump for power.
<small>[ October 10, 2004, 10:20 AM: Message edited by: OsoSlo z28 ]</small>
"MR." Ashley Fowler
'02 Yamaha Warrior (1700cc)
'94 MX-3 RS-t (BPT)~ sold
cardomain pics
"MR." Ashley Fowler
cardomain pics
hi! Yes, i think the fuel pump is not working cause i unpluged one of the fuel hose and no fuel is coming out and there ain't any noise coming from the fuel pump when i turn the key.Thxs
