Anyone swap thier 4cyl muffler for v6 muffler an how did it sound. I have the stock muffler on an want to upgrade because I have alot more flow now , but thier is no way I am putting one of those grapefruit shooter fart mufflers on my car, they have become soooo tacky around here, I like to keep somewhat with the sleaperlook ,lol might be a bit late though, atleast from a cops view from behind.
Eugene L
1.6DOHC
N.S.canada
http://www.cardomain.com/memberpage/552384
V6 Muffler upgrade
- Limegreen mx-3
Re: V6 Muffler upgrade
i tried the V6 stock muffler from the MX-6 loos great but to long to fit in the exhaust bay. i think the V6 mx-3 muffler will fit but what i did was grap one from a protege LX its a tight fit but u have to cut off the two little tail pipes and weld them back on. sounds great or at least it did till i put my OBX exhaust one. now i have a bolt on go from stock to OBX exhaust. hope that helps out latersOriginally posted by Ehpl:
Eugene L
1.6DOHC
N.S.canada
Drifter MX-3
- papa roached
the stock 1.8 muffler should bolt right onto your RS
Just get an aftermarket like a flowmaster or something. They've got a great sound and they arent the straight throught can type. Or check out the pacesetter exhaust system made for the mx-3, it looks pretty nice.
