HEADER QUESTION
mx3freak139
HEADER QUESTION
Post by mx3freak139 »
I READ ABOUT HOW SOMEONE TOOK THE HEADER FOR THE PROBE 4CLYD AND MADE IT FIT THE DOHC I WAS WONDERING IF YOU COULD DO THE SAME FOR THE SOHC
torpedan
Re: HEADER QUESTION
Post by torpedan »
First off, dude lay off the caps i dont care if your blind and you cant read. I would rather see it misspelled than in caps.
USe the search functoin this has been touched on a lot before. The SOHC is too diffrent i belive btw.
-torp.
I don't own a Mazda.
mx3freak139
Re: HEADER QUESTION
sorry about the caps but know one answerd my question will the probe header work for the sohc like it did for the dohc
torpedan
Re: HEADER QUESTION
Post by torpedan »
-torp.
MX-3RR
Re: HEADER QUESTION
Post by MX-3RR »
what I did was: I got a brand new ractive 4-2-1 headers for the honda b16, went to a exhaust house and they custom made a flange of the original headers, then welded to the ractive headers and VOILA; imediate power.
papa roached
Re: HEADER QUESTION
Post by papa roached »
good idea
mx3freak139
Re: HEADER QUESTION
pics???
how much did it cost
MX-3RR
Re: HEADER QUESTION
Post by MX-3RR »
ractive stainless steel 4-2-1 about 300 dollars plus 125 dollars for the custom flange plus 50 for weldings and assembly. Ill try show pics of all my mx. I know Its expensive but the power gain is pretty good.
