The Car’s you can get a bp from are 1991-1995 Escort GT, 1990-94 Protégé LX(us) GT(Canada) and 1990-1994 Mercury Tracer LTS
92-93 with stock tranny
Parts needed: BP engine and ecu (*harness optional*)
you will have to use your stock clutch and flywheel
92-93 with bp tranny
Parts needed: BP engine, ecu, tranny, clutch, flywheel, 3 axels and mounting bracket for the tranny under battery tray (*harness optional*)
*If you do not get the bp harness u will have to run 2 wires from the ecu to the vics, or get a window switch to open the vics *
94+ with stock tranny
Parts needed: BP engine, harness and ecu
94+ with bp tranny
Parts needed: BP engine, ecu, harness, tranny, clutch, flywheel, 3 axels and mounting bracket for the tranny under battery tray
i think with the 94+ swap u need the bp(from cars with a bp) coil but not sure
if anyone has info to add to this so we can put it in the faq to help out people looking to do the swap
<small>[ February 11, 2004, 09:34 PM: Message edited by: Marlon ]</small>
