Hey,
I am planning on doing this swap and the garage i am probally going to take it to said they would do it for $1200 CDN but i needed to get the parts etc, my self. So i have been doing research on this site and i have i list which i am going to go by. So can you guys give me some feedback. Oh ya this is just a daily driver, running stock psi or maybe just over.<p>Here we go,<p>- bpt engine
- ecu from 323
- wiring harness from 323
- knock control module
- 90-94 5spd tranny & axels (Need, side tranny mount bracket, along with all other parts if possible like, clutch slave)
- 1.8L DOHC flywheel
- ACT clutch
- fuel pump - from 2nd,3rd generation turbo
- AFC - Only if the ECU is not Japanese
- Boost controller - Manual, less money
- BOV
- Guages - Boost, A/F (EGT) Is this last one necissary
- Intercooler - What size?
- Piping - 2.25"<p>Is this the right stuff to do the swap, and keep it running as a daily driver? Oh ya i know to change belts etc.<p>Thanks, in advance!!!!
Travis
Bpt Swap List
Bpt Swap List
~~McLaw~~
MX-3 -- BPT
MX-3 -- BPT
Re: Bpt Swap List
Contact me at xnerx@rcn.com or on AIM at mx3TT. I have a gtx harness and ecu for sale ![Smile :)](./images/smilies/icon_smile.gif)
- ryanlindenberg
Re: Bpt Swap List
if you have a electronic speed sensor (94+ models i believe) you will need a speed sensor from a V6 MX-6., or change to the pre-94 guage cluster (i don't think your clock will work if you do this)
P.S. expect to have to buy most of the sensors that come with the motor, they are usually busted to ****. and cap, rotor, wires
<small>[ September 23, 2003, 01:06 AM: Message edited by: ryanlindenberg ]</small>
CARDOMAIN WITH UPDATED PICS
Re: Bpt Swap List
aight, help a fellow out here.
so If i buy a BPT engine and wanna swap, i would need a new gauge cluster. Do they all work with that stupid speedo cable that 4cyl SOHC mx3s have.![Confused2 :confused2:](./images/smilies/confused2.gif)
![Image](http://www.sikbluemx3.com/sigs_4.jpg)
Re: Bpt Swap List
does purchasing the entire front clip of a JDM mazda protege with the chasis code of BG8Z/BG8R sound good. it comes with RADIATOR,TURBO,PIPING, INTERCOOLER,TRANSMISSION,HARNESS, ECU ,COMPLETE HARNESS,IGNITOR,MAF and some other stuff that not listed such as axles and stuff i am guessing.
Re: Bpt Swap List
Well what you will def need is the tranny, ecu, hanress, MAF. The radiator you can use your stock one and also the intercooler is up to you. If you want to go stock or go with a front mount. But it depends on the price of the front clip compared to what you can buy individually.Originally posted by kuruption1983:
