NEED THIS DONE TONIGHT
Mx-3 Xplod
Post by Mx-3 Xplod »
my wheel bearings are shot and i got everything off and i can see the wheel bearing how do i get the bearing housing out?? please help i gotta get this done tonight.
i shall drop and rx-7 twin turbo in my 93 4 banger
ryanlindenberg
Re: NEED THIS DONE TONIGHT
Post by ryanlindenberg »
punch and hammer. be sure not to scratch the inside of the hub
CARDOMAIN WITH UPDATED PICS
jaydog5678
Post by jaydog5678 »
press.
atila
Post by atila »
Good luck doing it at home. The bearing his in the center of the spindle and there's the cage that will be on the hub. to remove the bearing from the spindle you need a press and to remove the cage from the bearing you need a set of torch. you heat the cage until it's red then you put it into water and it should fall off.
