1.8L DOHC BP ENGINE QUESTION
At first i will just swap a Bp 1.8L dohc engine into my 1993 Sohc mx3 and my next step will be to turbo it. I know I have the option to get the bpt engine but money is going to cost alot more to do everything at once. I'm going to take it step by step. Anyways here are my questions.<p>1. How much pound of boost can the bp 1.8L dohc block take before blowing?<p>2. Does the 1990 to 1994 bp 1.8L dohc engine bring the transmission that tells the speed of the car to the cluster by a cable that comes out the transmisson?<p>3. Do you guys know any website where i can go and get performance parts for that engine like forged pistons and rods?<p>4. How much horses does the bp 1.8L dohc engine come with?
Re: 1.8L DOHC BP ENGINE QUESTION
If ya look around you can find answeres to most of these questions by searching here or in the forced induction board.<p>1. 10-12 (i think memory is foggy)
2. you will either have to fabricate soemthing or have a hybrid setup the mx3 speedometer system is electrcal whereas the bp is cable driven.
3. Do your research on the motor the results may suprise you.
4.125
4.125
-torp.
I don't own a Mazda.
the regular BP will take upwards of 30 lbs of boost if you tune it right with enough fuel. Dave Lauzier and Ric have both shown this.<p>You dont need to ever look at aftermarket rods or pistons, as there's no use.<p>[ March 26, 2003: Message edited by: ProtegeSTS ]</p>
-93 MR2
#129 E-stock
#129 E-stock
- guyaverage
I am very open to the fact that I could be wrong here, but dont the earlier 1.6 Mx3's use a cable for the speedometer? I just read on one other website that it does....
"The answer is: More power. I dont care what the question is."
-Tim Allen
-Tim Allen
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>I am very open to the fact that I could be wrong here, but dont the earlier 1.6 Mx3's use a cable for the speedometer? I just read on one other website that it does.... <hr></blockquote><p>anyone have an answer on this? im intrested as in I need to know if my 92 tranny will work or not..
![Image](http://members.aol.com/march25/mx3sig.gif)
92 red rs
performance exhaust
zx2 struts and Eibach springs
turboed + stand alone when the cash is there
- Custommx3
- Site Administrator
Some earlier model SOHC speeds had a speedo cable. Only way to find out is to takeit out as far as I know. I've never heard of a GS with a speedocable, I have a 1992, and I have taked out 3-4 different 92 clusters.
- guyaverage
I just went out and checked, I definitely DO have a speedometer cable, runs up from just behind the drivers side of the engine and up thru a grommet on the firewall directly behind the instrument panel. Thats on a 1993 1.6 SOHC w/automatic.
-Tim Allen
-Tim Allen
As far as the 1992-93 SOHC MX3 transmission goes the speedometer is cable. The question I was asking was if the protege LX transmission
speedometer was cable. From the replies I have gotten from the protege website I have realized that the 1990-94 do have cable. <p>Now from all the reasearch I have done, I keep on reading about haveing an axel problem when the BP engine is installed in the car. Now this is confusing because I have heard a bunch of solutions but dont know which one is true. These are the solutions I've heard.<p>1. To usel the V6 right axel and jackshaft
2. That the 92-93 straight axels do not use a jackshaft and it can be used for the right side of the transmission
3. I heard just to cut the protege axels and weldit back to make it shorter so it would fit our cars.<p>My question is which is true?
Straight axles from experience work done it on my friend precidia rs 94 when i put my old bp in his car.
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by jap:
1. How much pound of boost can the bp 1.8L dohc block take before blowing?<p>2. Does the 1990 to 1994 bp 1.8L dohc engine bring the transmission that tells the speed of the car to the cluster by a cable that comes out the transmisson?<hr></blockquote><p>the 1.8 bp block has the same bottom end as the gtx but with slightly higher CR. the only problem you run into is the caps tend to want to leave around 300-350hp.<p>yes, the 90-94 bp uses a cable speedo gear. you'll probably have to use the one with the tranny as it doesn't stick as far down as the mx3 gear.<p>with the axle problem...you CAN use a straight axle, but it's best to just get the jack-shaft from the 90-94 pro lx and get 90-94 pro lx drive shafts. works great.
"MR." Ashley Fowler
'02 Yamaha Warrior (1700cc)
'94 MX-3 RS-t (BPT)~ sold
cardomain pics
"MR." Ashley Fowler
cardomain pics
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by cre8v mx3:
<p> the only problem you run into is the caps tend to want to leave around 300-350hp.<hr></blockquote><p>Must suck not to have a beefy split block/girdle design like the V6's :p <p>![Image](http://homepage.ntlworld.com/dorothy.bradbury/probemx/images/v6.gif)
David Coleman
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by David Coleman:
<p>[ March 30, 2003: Message edited by: cre8v mx3 ]</p>
"MR." Ashley Fowler
cardomain pics
"MR." Ashley Fowler
cardomain pics
<p>Must suck not to have a beefy split block/girdle design like the V6's :p <p>:p
-93 MR2
#129 E-stock
#129 E-stock
hahaha I love you guys
92 red rs
performance exhaust
where are you getting this motor from? why not think of getting a j-spec 1.8dhoc bp turbo for about 1100 dollars through corksport. a friend of mine has the kl-ze j-spec in his 94 probe with a little bore done to it and a few things i refuses to tell anyone...and we are going to be turboing it soon we hope! pray with us that he gets money!! and from what ive seen his car do its a great engine and it would be a good idea to go with that...i know i am one day someday when i get money!! good luck to all with their cars
i got a 90 pgt...but wish it was a mx-3 bp-t!
<img src="http://titan-racing.com/img/tr_site_logo.jpg" alt=" - " />
