RX-7 MAF
- papa roached
RX-7 MAF
how much of performance difference will i see if i get a 88-89 RX-7 MAF and put it on my 92 1.6 SOHC?
Re: RX-7 MAF
So far from what i read the rx7 maf helps the car to get air better.. adds 1-3 hp. Also its real good idea to get one if u r going to turbocharge your car..Thats about all i read..
Hot damn its a new day!!
http://www.cardomain.com/id/nappyforawhile(Updated)
Re: RX-7 MAF
on proteges with a bp they get 6 hp so i would guess 2 or 3 but at high rpm
1993 MX-3 GS V6 - Stock
2004 MazdaSpeed MX-5
2004 RX-8 - Project
2004 RX-8 - Project
- mitmaks
Re: RX-7 MAF
will it fit only on rs or on gs too?
Re: RX-7 MAF
Here's one on ebay I saw, starting bid is $9.99.<p>Looks just like our stock ones...<p>![Image](http://ebay2.ipixmedia.com/abc/M28/_EBAY_4b469286ba70ca78130fa5d9c2a77dba/i-1.JPG)
Re: RX-7 MAF
It won't do you a bit of good. The 1.6 doesnt breathe enough to take advantage of it.
-93 MR2
#129 E-stock
#129 E-stock
- The_Great_Tonge
Re: RX-7 MAF
well has anyone swap that maf for theres on a RS? if so did you feel any gains? is it worth it? because some say it does work and some say it doesnt. so if someone who has done it could speak up it would be nice, thanks!
- mitmaks
Re: RX-7 MAF
ya i wanna know too, for my gs, gotta have all hp i can get
Re: RX-7 MAF
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by The_Great_Tonge:
well has anyone swap that maf for theres on a RS? if so did you feel any gains? is it worth it? because some say it does work and some say it doesnt. so if someone who has done it could speak up it would be nice, thanks!<hr></blockquote><p>________________________________________<p>From Randy Stocker,
"If you never turn the motor past 6000 rpm then you'd be wasting your time. The factory flowmeter CFM threshold before limiting HP is about 6000 rpm with the 1.6 motor (the stock engine will flow 178 CFM at 7200 rpm while the meter is rated only at 165CFM). If your 1.6 motor is relatively unmodified (maybe a performance muffler and intake plumbing) but you regularly go past 6000 rpm then putting the RX-7 unit in will produce about a 5 HP gain, you'll probably only notice it after 6000 rpm though."
__________________________________________<p>You have a motor that doesn't breathe as well as the 1.6L miata. Unless you're running cams, it's useless.
-93 MR2
#129 E-stock
#129 E-stock
Re: RX-7 MAF
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by mitmaks:
ya i wanna know too, for my gs, gotta have all hp i can get<hr></blockquote><p>The GS and RS don't even use the same TYPE of airflow meter!!!![Mad :mad:](./images/smilies/icon_mad.gif)
-93 MR2
#129 E-stock
#129 E-stock
- The_Great_Tonge
Re: RX-7 MAF
well if anone with a MAZDA MX3 has done it could they please speak up, thank you ![Very Happy :D](./images/smilies/icon_biggrin.gif)
