Ground wire kit
azmtbkr81
Ground wire kit
Post by azmtbkr81 »
I read in Import Tuner about a ground wire kit that added 5 hp to a suzuki aerio, the kits are universal and I was just wondering if anyone had tried one of these on their mx-3, seems like a pretty cool mod.
'94 Blaze Red RS<P>I may not have a lot of horsepower but I know how to use it!
Paragon
Re: Ground wire kit
Post by Paragon »
what exactly is a ground wire kit? if it's just a beefed up negative wire that goes from the batt to the chassis, i don't see how that adds power
azmtbkr81
Re: Ground wire kit
Post by azmtbkr81 »
supposedly it reduces electrical resistance on the engine, I beleive it is actually a set of various wires that attach to different points on the engine and chassis. I was skeptical about it before reading the article but they threw the car on a dyno and it gained a solid 5 hp and about the same amount of torque.
marshmallow15
Re: Ground wire kit
Post by marshmallow15 »
yea ive seen that too. i think it'd vary on cars and the only way to see a true increase is if someone can test this on the mx3 with a dyno.
- team slideways
tk1138
Re: Ground wire kit
Post by tk1138 »
You'll get a bit more power, not 5 though. Any time electrical loads are heavy, bigger wires are recomended. It's pretty much a must for big audio.
tk1138<P>There's not really anything I want to say over and over.
ProtegeSTS
Re: Ground wire kit
Post by ProtegeSTS »
Its also a popular mod with the Subaru guys. They have issues with misfires because the stock grounding straps are crappy. It'll never hurt if nothing else.
-93 MR2
#129 E-stock
monty73741
Re: Ground wire kit
Post by monty73741 »
i upgradded mine.........<BR>its more a visual thing........<BR>but my grounds looked old though<BR>but i have not notices a hp increase<BR>jason
Jason Danaher
Please Help Support MX-3.com
992mmx3
Re: Ground wire kit
Post by 992mmx3 »
I see them all the time on ebay, i was thinking about getting some but we'll see. Hey protegests, what do you have done to your mr2?
-Mark Lathrop
1992 MX-3 RS-T
B6T with some goodies
azmtbkr81
Re: Ground wire kit
Post by azmtbkr81 »
I don't know that I would want to get the e-bay brand, this XS Engineering kit seems like it is much higher quality and better designed than anything else. It has ultra pure copper wire and uses a daisy-chain design instead of all the wires stemming out from one central grounding block. You guys should check out the Dec. 2002 issue of Import Tuner because this seems like a great mod for our MX-3s. They dyno tested the wire on 4 cars and here is how the gains break down:<P>2002 Suzuki Aerio sx:<BR>max gain: 3.9 hp(sorry my original number of 5hp was a little off)<BR>avg. gain over entire power band: 1.5<P>2002 Honda S2000:<BR>max gain: 2.1<BR>avg. gain: 1.03<P>1995 RX-7 TT:<BR>max gain: 15.3<BR>avg gain: 7.09<P>1997 Nissan Maxima:<BR>max gain: 11.6<BR>avg gain: 6.23<P>Of course we arn't going to see gains like the RX-7 did, but considering that the wires are $100 and saying that we may gain an avg. of 2 hp its not a bad deal. <P>I don't think that the XS wires are available yet but I will probably buy a set when they are and let you guys know if they make a difference.
jonathanj
Re: Ground wire kit
Post by jonathanj »
the wires are available. they are actually from a company in japan called sun auto. when i went to L.A. for hot import nights we stopped a this japanese guys shop. he had them in stock and also had them on his 500hp silvia. he said he dynoed it and gained 17.hp at the wheels. it seemed to good to be true but after reading the import tuner i beleive it now.heres a link to his site. <A HREF="http://www.enonvativforce.com/" TARGET=_blank>http://www.enonvativforce.com/</A> <BR>good luck
marshmallow15
Re: Ground wire kit
maybe the kit might also help with the alternator/stalling problem that a lot of mx3s have.
- team slideways
