HELP!! oil coming from bolt on valve cover?????
Exactly what the subject says. I've got a bolt...far left on the middle of the valve cover that seems to be leaking really small amounts of oil out of it. I lifted the spark plug rubber near the plug and noticed some oil under it...what do you guys/gals think it is.. I have already changed the bolt once and that didn't solve the problem.<P>I was told by a mazda guy that it might be that the valve cover needs changing, but I just did this around October/November myself.<P>Any suggestions?<P>Chris
- mmonid
Re: HELP!! oil coming from bolt on valve cover?????
Could it be that there is too much oil in the engine? It could be overflowing. Just a thought.
Matthew Monid
1993 MX-3 RS 5-Speed (Sold)/1997 Volvo 850 AWD Turbo 5-Speed
Wheelz
Mine was doing the same, leaking from one of the centre bolts, i replaced the valve cover gasket, and that solved the problem. Just don't overtighten the bolts when you put the cover back on or you will ruin the gasket and guess what, it's going to leak again
1993 MX-3 RS/GS-R Under Construction
