94 MX-3 on the chopping block, good extras
i recently bought a new(er) car and am putting the 94 GS MX-3 to pasture. there is a problem though. the thing is running like crap and wont smog. it is registered though, but no tags until it is smogged. i am desparate and am close to donating it to charity. here is the deal, i am in san diego ca, and would much rather see it go to a fan. it has some cool stuff on it:
-MS (replica) front nose
-tokiko struts (+/- 1000 miles)
-eibach springs (cut just a tad, 50k miles or so)
-front and rear corksport strut tower braces
-TWM Short Shifter (+/- 1000 miles)
-PRM Pro Kit Intake (+/- 1000 miles)
-Indiglo Gauge Faces
-KVR Cross-Drilled or Slotted Rotors (front and rear set, a bit rusty from sitting in the cold)
-Thule mounts
well there you have it. i can sell the lot for $1000 (neg), but you have to take the whole car. it runs, but sputters out at half or more throttle and i just cant figure it out and quite frankly dont have the time. i can part it out too, just make me an offer on what you want. keep in mind i will not take the stuff off (exept for the PRM intake, that is easy), but you can come over, i have a floor jack.
in case you are curious i got a 2001 Audi S4.
email me at:
darin at dlbn dot com
-Thule mounts
email me at:
Re: 94 MX-3 on the chopping block, good extras
what color is your car? i might be interested in body parts. that is if you decide to part it out
<small>[ July 30, 2004, 01:33 AM: Message edited by: illicitQ ]</small>
92 RS: BPT, evo front mount, custom 2.5 in IC pipes, apex-i SAFC- II, GReddy type-RS BOV, rear disc swap, GTX front strutbar, oem GS lower rear tie bar, Topspeed1 axle back exhaust, 15" TSW wrapped in yokohamas, power window swap. NOT INSTALLED: GReddy turbo timer and CS downpipe.
<img src="http://www.dlbn.com/images/mx.jpg" alt=" - " />
<small>[ July 30, 2004, 08:54 AM: Message edited by: Darin ]</small>
- bluebullet
if u wanna part the iniglow gauge faces then id be down 100% for usre!!!!
ill buy ur struts whats the pricing?
its your o2 sensors, my car did the same sputtering thing and worked great after replacing the o2 sensors.
I replaced em with a pair of 1-wire universal units that cost 17 each instead of the OEM relacements that cost over 80 each
BTW: nice car....i wish you lived closer, i'd buy it.
DONATE TO MX-3.COM
DONATE TO MX-3.COM
I'll take the entire gauge cluster with reverse glow gauges. I got armor all cleaner on my plastic clear cover and left it on there for a couple days in the heat, and it ruined my clear cover. E-mail me with a price. Tyler17rose@hotmail.com
Mods:
E-mail me with the price for the mazdaspeed replica, and the gauges, and i'd be happy to offer. ![Very Happy :D](./images/smilies/icon_biggrin.gif)
Did you try diagnosing the problem on here first?
i'll take the short shifter email me what your want for it
thanx
thanx
sold the mx-3 , bought 04 gtp comp g , from the smallest v6 to one of the biggest 3800 s/c FTW
It's funny how all these ppl from Canada and the mid-west are requesting parts from the car when he clearly stated that he doesn't have the time to remove thsee parts, unless you are local to SAN DIEGO and can remove them yourself.
Maybe you guys should read his post before requesting all these parts????
DONATE TO MX-3.COM
DONATE TO MX-3.COM
what a concept!
