succesful K8 turbocharged @10 psi!!
Re: succesful K8 turbocharged @10 psi!!
Update: I was running without the AFPR and with a 12:1 Fmu disk, now I swapped to a 8:1 disk, the afpr, and still Kl injectors. I was flodding past 5500 Rpm! I´ll say you anything as soon as I have my new radiator installed!
European Mx3 GsRT
excellent ![Smile :)](./images/smilies/icon_smile.gif)
new radiator is here!!
Mine was impossible to repair due to a crack in a plastic case, so now I have an aftermarket new one which weights the double!!! I will finish my car tonight, hope the heads are Ok after the heat up due to the water loss
Well, gone to work!!!
![Mad :mad:](./images/smilies/icon_mad.gif)
European Mx3 GsRT
update:
I am investigating on adapting a thermical interchanger water-air as an intercooler. I must need to know what efficiency it has, but it look really compact!!
European Mx3 GsRT
t35, stock injectors, stock(?) fuel pump,12:1 fmu and safc.
I`m planning on running 8 psi max, would I then need a 12:1 fmu, isn`t that a bit overkill?
Also, is the stock injectors big enough to handle the fuelflow needed for 8 psi if I go with a walbro 225 pump?
Does anyone have an aprox. price for these parts too?
nope-mx3
nope-mx3
- babyblueMX3
don't get that vortech fmu...It's a pain to shange disc..go with the cartech 2025..a little more priecy but worth it ...You can set base fuel pressure (off boost) and turn a screw to set the rising rate (4:1 - 12:1)..unlike that vortech fmu...easier and better ![Smile :)](./images/smilies/icon_smile.gif)
RIP 400whp ZE-T MX-3
wich injectors are easiest to get for the Mx3?
220cc/min seems to be enough.
Also, with an fmu, do I need en extra inline fuelpump? Dont see myself doing anymore than maximun 8 psi of boost.
Does anyone have any clue as to how much whp I should expect?
nope-mx3
NB, Battosai: how did you install the walbro pump in the tank? is it easy to replace the oem pump?
<small>[ August 17, 2004, 11:45 AM: Message edited by: nope-mx3 ]</small>
nope-mx3
- papa roached
the in tank upgrade is uber-easy
