succesful K8 turbocharged @10 psi!!
BATTOSAI
Post by BATTOSAI »
Finally I have made it! I was crazy thinking that I got no boost because my wastegate wasn´t closing perfectly, and the fact was that it opened at the slightest boost sign!
I set my boost at 5 psi with a t35, stock injectors, fuel pump,12:1 fmu and safc and hold it perfectly. Then I noticed that past 8 psi the car leaned really fast, so Iinstalled the 220 cc/min kl injectors with my Walbro 255 lph fuel pump and can run the 10 psi without overheating, pinging, or running lean!
The next step will be swapping my intercooler for one bigger, so the charge will be cooler!
Keep you updated!!!
<small>[ September 30, 2003, 10:09 AM: Message edited by: BATTOSAI ]</small>
European Mx3 GsRT
BATTOSAI
Re: succesful K8 turbocharged @10 psi!!
Post by BATTOSAI »
Oh , I forgot! full boost at 4000 ( not really good) but it´s REALLY FAST!!!!
European Mx3 GsRT
Sonicxtacy02
Post by Sonicxtacy02 »
get ya butt to a dyno :D congrats man its been a long time comin
Shaun Newman
monstar-mx-3
Post by monstar-mx-3 »
any pics of the layout?
Tyler17rose
Post by Tyler17rose »
Sweet!!!!!! I wana see power numbers here! And a estimated total cost? PICS! Videos anything! this is awsome!
Mods:
2RotorsNaDream
Post by 2RotorsNaDream »
Why'd you turbo the K8? You should've gone wit the KL-03, it can just as easily run on 10psi and it gets more power. Anyways good job congrats on the install and I'm sure later you can use the same setup more or less if you decide to upgrade to a KL-03.
Image1993 Mazda RX-7 Touring Edition Innocent Blue Mica- Not stock...
1993 Teal MX-3 GS- KLZE and other goodies. RIP
papa roached
Post by papa roached »
he could just swap his setup over to a KL-03
torpedan
Post by torpedan »
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by Illa Killa:
Why'd you turbo the K8? You should've gone wit the KL-03, it can just as easily run on 10psi and it gets more power. Anyways good job congrats on the install and I'm sure later you can use the same setup more or less if you decide to upgrade to a KL-03.<hr></blockquote><p>So when a person like you comes along he can call you a ********* for ridculing him for doing something cool..<p>
good work dude nicee to hear of things like this being done.. even if everyone can not appricate it.
-torp.
I don't own a Mazda.
Spydie
Post by Spydie »
a K8 is actually more turbo ready than any KL engine. Smaller ports and fewer overlaps. Non aggressive cams....very safe. Less power overall, but very safe.
lakersfan1
Post by lakersfan1 »
I'd like to see a stock dyno chart, and the turbo'd dyno chart, then compare. Also would like to see a product list and price list of everything you bought to make the turbo kit.
2RotorsNaDream
Yo torpedan what are you talking about? I didnt call him anything derogetory nor did I hate on his accomplishment. I told him congrats and complimented him. All I asked was why he didnt use a bigger engine that he could've used the same setup on when the engine is very cheap and very easy to get out of curiosity. Next time mind your business. And Darren I know the K8 is more turbo friendly but I also know first hand that a turbo KL-03 can easily be just as safe and can make bigger gains than the K8. I see a great example of a safe turbo KL-03 everyday and it's got lots of miles on it too.
i do agree that torpedan did jump the gun a bit, it was a fair question that didnt deserve that type of reply, i know i would have asked that question
monty73741
Post by monty73741 »
just a quick question<p>
what is abrams running for boost
Jason Danaher
Please Help Support MX-3.com
2RotorsNaDream
thats the MX3 GS stock engine.
Return to “Forced Induction”
