Cold air intake possible?
Yes, the EBay Cold air intake which is made for the SOHC version of our cars WILL work. I did it myself and only takes about an hour or two (depending on how unorganized with your tools you are.. like me!
Also I did fine only using the stuff that came in the box (adapters and what not), but after while i did notice a piece of adapter starting to come off my MAF (Mass Air Flow Sensor) and bought a new one from AutoZone (2.5" to 3") and used that instead. ever since then it's worked perfectly and sounds friggin awesome...
At home, there's a long stretch of road, if i floor it and get the engine pumping hard around 3500 RPM it sounds like a beast.. always turns heads![Razz :P](./images/smilies/icon_razz.gif)
If you need pictures.. ill be glad to supply some.
-Chris
-Chris
