[FS] SRD Reproduction Parts - Crossmember, Tie Bar & E-Brake
New product ideas and status of new product development postings.
SmoothMX3
Re: [GI] Aluminum Crossmember & Rear Tie Bar - SRD Reproduction
Post by SmoothMX3 »
$200.00 just for a front strut bar?! omg lmao
--- K8 was my gateway drug.
rekognize
Post by rekognize »
SmoothMX3 wrote:$200.00 just for a front strut bar?! omg lmao
I believe it's $200 for the v6 crossmember
So far prices are determined at $100 for the tie bar, and $200 for the crossmember.
fowljesse
Post by fowljesse »
Nd4SpdSe wrote:I was able to pull up some info and that SRD was planning on selling a kit with bolts and blind fasteners for the 4cyl guys. I'm not sure if it's possible, but Jesse, would it be possible to do a quick test-fit on a 4cyl, possibly Jared's Mx, and see if it's possible to figure something out. Jeff said the holes didn't line up when he went to test fit them on on his, but I don't have anyone to verify that.
Just a note that the 2 prototypes have been sent to Jesse on the 20th, and the last tracking update that it arrived into the "destination country" on the 22nd.
Yeah, I'll ask Jarid. I'm sure he'll be into it.
hotsiit
Post by hotsiit »
^--I would be interested in seeing how you could adapt this srd-v6 replica front crossmember to fit a 4cyl mx-3...I have no doubt with all you Oregon mx-3ers and Jarid's shop you guys could find a semi easy way to make it work.
:D
1993 Mazda MX-3 RS-Turbo
1993 Mazda RX-7 touring
1983 Mazda RX-7 GSL
1987 Jeep Comanche
cjthor
Post by cjthor »
Im in! Actually the MX was on the lift yesterday!
Jarid Perry
71 Chevy C20 (tow rig!!)
2008 MINI Cooper Clubman S
nightfire
Post by nightfire »
Just out of curiosity, does anyone make an aluminum longitudinal crossmember (the one the engine bolts up to) which is stronger and lighter weight?
- Gord
1996 MX-3 GS-ZE 2.5L 5spd
KLZE+LSD / Headers / KL02 VAF / Clutchmasters stage-I / Fidanza 9lb flywheel / Eibach Pro Kit / Tokico HPs / Urethane bushings & mounts / SSR Comp-C 16x7 / General Exclaim UHP 205/45R16 / Wilwood 13" brakes / Whiteline rear swaybar / Carputer / Software Crossover / Infinity components+subs / 41hz Tripath Amp9 / Trunk SLA batt / Keyless entry
marcdh
Post by marcdh »
Not to my knowledge, guess it does it's job ok so no one cares much! One adapted for the ebay turbo pipes might sell a bit though hardly huge market.
View Worklog
Flyer
Post by Flyer »
BlaznLow wrote:
fowljesse wrote:HI, Jim. I'm the guy who's going to try to beat them up :wink: There's a market for other Aluminum, and other metal stuff here!
enjoy beating the hell out of them. should be pretty fun.
what else is there that people want?
Control arms? TTLs? Everything suspension-related? XD
Oh1 I got a good one! FRONT lower tie bar :P
Flyer wrote:Control arms? TTLs? Everything suspension-related?
Honestly...I have SERIOUSLY been thinking about those the last while...
onlytrueromeo
Post by onlytrueromeo »
They'd have to be alot cheaper than 100 a piece or you'll be spending quite a bit :wink:
Post by wytbishop »
Flyer wrote:Control arms? TTLs? Everything suspension-related? XD
I've been thinking about it a lot too...and making designs.
Flyer
Post by Flyer »
Exactly! It will complement the bushings!
nightfire
Post by nightfire »
Actually, what about general purpose chassis reinforcement bars? They would be tough to engineer, but I'm thinking something with high tortional strength in a cross pattern under the middle of the car, at the rear, etc. Something bolt-on, not requiring welding, using existing boltholes on the frame. And something lightweight (ie. <50lbs).
The MX-3's chassis is decently rigid already, but nothing compared to the 911 I've been driving around lately. :)
There are quite a few creaks under high loading, especially from the rear.
In fact if you want to see how bad the flex can be, park one wheel on a rock, up say 3", and try to open/close the trunk.
- Gord
Flyer
Post by Flyer »
nightfire wrote:Actually, what about general purpose chassis reinforcement bars? They would be tough to engineer, but I'm thinking something with high tortional strength in a cross pattern under the middle of the car, at the rear, etc. Something bolt-on, not requiring welding, using existing boltholes on the frame. And something lightweight (ie. <50lbs).
Something like this?
Return to “New Product Development”
