I have a 93' MX-3 and for some reason on the driver side door the key is not able to turn and, I feel the key starting to bend.
I tried it on the passenger side door and it worked fine.
What can be the problem , and where can I buy a new replacement?
I just bought this car today so its all very new to me.
Thank You, Nick
MX3 LOCK STUCK??
MX3 LOCK STUCK??
N A O
Re: MX3 LOCK STUCK??
i had the same problem on my 94 rs.....WD40 is a beautiful thing....spray a bit in the key hole...work it a bit. should clear right up
some peoples kids.
Thanks for the reply and help. Ill try it next thing in the morning.Originally posted by dr. gonzo:
N A O
try brake fluid on my sentra my trunk lock was completely seized with a little playing it became unseized.
- Yoda
I use Break-Free CLP. Unlike WD-40 is a longer lasting lubricant, preservative. It also eat through corrosion and build-up of foreign matter. WD-40 works more by displacing water, loose rust and dried lubricants then that lubricating value evaporates off. Break-Free lubricates immediately but gets better as it cure which unlike WD-40 continues to prevent water and grit from getting into the mechanisms. The other good thing about it is it doesn't damage most paints and finishes. It is not available at automotive stores but at gun shops and sporting dept. at Wal-marts in the US.
