Possibly easy fix....?
quick question... while im at work. haha! since i work 45-50 hrs a week i usually dont have time to mess with alot of things on my car, although i still love it to death haha. my horn stopped working. when i press it there is a clicking sound underneath the dash but no horn sound
?! i havent had a chance to play with it yet but i was wondering maybe someone else has run across this problem?! no rush, i just hope someone knows this answer?! thanks!
95 Mazda MX-3 DOHC 4cyl.. 17's, Cat Back w/ 4.5in Tip, Custom Int.(CF Bezel,White and Black, 7"AutoMeter Tach, 4 Neons Hit W/ Bass, $375 Kenwood Headunit), $1300 Custom System(Including 2.25Farad Cap. Custom Built Box w/ 2 cut outs for 6x9's, 2 12" Infinity's, 1200w Amp, 4 tweeters. It might not be as fast, but it sure as hell looks and sounds better than a Honda! CF Invert. hood! Primer&Fittin Drift Front and Sides w/ K-Max Rear.
Re: Possibly easy fix....?
could be a fuse..maybe.
if its clicking its not the fuce its the actual horn. Check the connections, if theyre good its most likely the horn itself
- guyaverage
The click you are hearing is the horn relay. The horn switch activates an electronic switch (the relay you are hearing) which completes the current to the horn. Check the wires to the horn itself (under the front bumper) and see if they are still connected or if the connectors are corroded.
-Tim Allen
-Tim Allen
- ryanlindenberg
could be the relay itself also...
CARDOMAIN WITH UPDATED PICS
have someone push the horn, while you try to find exactly where it is clicking. Relay or horn itself. the relay may be bad, or the current is finding ground somewhere. Check wiring, it could be as simple as a splice.
If not broke - don't fix, modify. If broke - fix it right, and make it better.
