Car won't run
Car won't run
I got a 94 mazda mx3 4V 73k miles a few months ago. It ran fine when I bought it however now, it wont run, I can start it up fine but no matter what gear I put it into, it doesn't run. It doesn't stall when its suppose to. I dont even need to push the clutch to put it in gear. Also, before it died, I had to accelerate really hard on the gas for it to run. My engine meter was up to like 6 or 7 and it barely ran 25 mph. Anyone know whats wrong? I asked someone and they said it might be the transmission. And if it is the transmission, would I have to buy a new transmission or can I get an old one?
- Typhoonk
Re: Car won't run
Get a small garage to test drive it. The worst it will be is the tranny. Could also just be the clutch
Here's hoping
Here's hoping
PM for info
PM for info
Re: Car won't run
Clutch is toasted.Originally posted by zw12345:
92 MX-3 RS,
Racing Mazda turbo kit. 451 WHP @ 25 psi
12.1 @ 117 mph w/318whp
http://www.cardomain.com/memberpage/652555
- MX3-Freak
Re: Car won't run
I suppose by "run" you mean move, and by " engine meter was up to like 6 or 7" you mean tachometer was at 6k/7k rpm? If so, you need a new clutch...although ive never seen one get that bad before so quickly .Originally posted by zw12345:
Stock 1995 RS - Creek Blue
Car Meanins:
Car Meanins:
- papa roached
Re: Car won't run
most def the clutch
- monty73741
Re: Car won't run
i had the same type of problem & i thought it was the clutch it turned out to be the disty
Jason Danaher
Please Help Support MX-3.com
Re: Car won't run
I wish i had a stick in my MX-3
