Car won't run
zw12345
Car won't run
Post by zw12345 »
I got a 94 mazda mx3 4V 73k miles a few months ago. It ran fine when I bought it however now, it wont run, I can start it up fine but no matter what gear I put it into, it doesn't run. It doesn't stall when its suppose to. I dont even need to push the clutch to put it in gear. Also, before it died, I had to accelerate really hard on the gas for it to run. My engine meter was up to like 6 or 7 and it barely ran 25 mph. Anyone know whats wrong? I asked someone and they said it might be the transmission. And if it is the transmission, would I have to buy a new transmission or can I get an old one?
Typhoonk
Re: Car won't run
Post by Typhoonk »
Get a small garage to test drive it. The worst it will be is the tranny. Could also just be the clutch
Here's hoping :D
PM for info
Ma-Ze
Re: Car won't run
Post by Ma-Ze »
Clutch is toasted.
92 MX-3 RS,
Racing Mazda turbo kit. 451 WHP @ 25 psi
12.1 @ 117 mph w/318whp
http://www.cardomain.com/memberpage/652555
MX3-Freak
Re: Car won't run
Post by MX3-Freak »
I suppose by "run" you mean move, and by " engine meter was up to like 6 or 7" you mean tachometer was at 6k/7k rpm? If so, you need a new clutch...although ive never seen one get that bad before so quickly :confused2: .
Stock 1995 RS - Creek Blue
Car Meanins:
papa roached
Re: Car won't run
Post by papa roached »
most def the clutch
monty73741
Re: Car won't run
Post by monty73741 »
i had the same type of problem & i thought it was the clutch it turned out to be the disty
Jason Danaher
Please Help Support MX-3.com
AllisMitchChalmers
Re: Car won't run
Post by AllisMitchChalmers »
I wish i had a stick in my MX-3 :driver:
