Finally an intake for the i4's
lil_gary
Re: Finally an intake for the i4's
Post by lil_gary »
Heres a link to the pics I have of the intake, I know they look horrible but I was in a hurry
Peace
Intake Pictures :D :2thumbsup:
"I Am We Tall Did"
Say it loud
Say it proud.
Support Mx-3.com Click here for Mx-3 Products.
To search for a topic on the Mx-3 Bullletin Board click here
Searching gives a instant response to questions
HoT_RaQz
Post by HoT_RaQz »
Nice pics . . . where precisely is the filter located, just inside the driver side part of the bumper? Looks sweet!
Now if I can JUST find one for the DOHC . . . :froggie_red:
:pimp:
Brand Newbian . . .
1994 Black RS Precidia
Stock as PHUCK . . . :pimp:
lil_gary
Post by lil_gary »
Yeah the filter is located in between the fender and sub-frame. I guess its called a sub-frame.
NE-Ways its in that little cubby hole under the radiator overflow resivior
"I Am We Tall Did"
Say it loud
Say it proud.
sweetmx3
Post by sweetmx3 »
intake looks nice any difference in per formance or gas mileage looks good though i probably are going to purchase one soon. :2thumbsup:
monty73741
Post by monty73741 »
it should fit the dohc.....i installin the same one...but probally gonna put on my prm instead of the cone filter
:pimp: [/QB][/QUOTE]
Jason Danaher
Please Help Support MX-3.com
lil_gary
Post by lil_gary »
Gas mialage i don't know about yet because I just installed yesterday, But as for performance it seems to be a lot smother through the RPM's and has more pick up
"I Am We Tall Did"
Say it loud
Say it proud.
LooseChangeRacing
Post by LooseChangeRacing »
does this work on 91 - 92? or is there a complete difference? I want a complete bolt-up CAI, does this one add MPG? maybe that whoop said too?
http://www.cardomain.com/ride/2385931/4
Car Name - Elsie (LC)
Car Type - 92 Black RS Stock 190k
Car Name - (yet to be decided)
Car Type - 93 (soon Black) GS KLZE 130k
MX3-Freak
Post by MX3-Freak »
It is meant to work on the SOHC, not the DOHC. You should have absolutely no modification on a 92 (which is SOHC). But why would you spend $70 on a system that you can make for $20 - $30 that is just as effective? Making it yourself isnt hard...get some pipe and piece it together. A 30 minute job if you know what you're doing. But hey, each to their own. :shrug:
Stock 1995 RS - Creek Blue
Car Meanins:
LooseChangeRacing
heh thats the thing, I don't know what I'm doing when it comes to my engine, I know the basics of car maintenence but for performance I'm a retard, I can handle everything else about a car execpt the engine, a to z except e, so actually I'm probably going to need help to put THIS one on after I spend $70 for it, unless one of you guys wants to make one for a 92 SOHC and I'll send you $50 heh
MX3-Freak
Post by MX3-Freak »
Damn, wish I had an SOHC to make one off of, then I would take up that offer. :confused:
Car Meanins:
mxprecidia
Post by mxprecidia »
does this fit dohc?
www.illegalCustoms.com
Tri-State Area Car Club
MX3-Freak
Post by MX3-Freak »
Yes - with slight modification.
Car Meanins:
Reprobation14
Post by Reprobation14 »
Gah! What need to be modified... and how so?
(DOHC), I have looked EVERYWHERE for a DOHC air intake system.. and found nothing... :| I don't really have a whole lot of tools at my disposal.. so im pretty limited on how i can modify it... unless you can do it with some tin sheers :p
-Chris
MX3-Freak
Post by MX3-Freak »
I believe the only modification will be at the maf. Since the SOHC MAF was square rather then round, they use an adapter plate. You could probibly just not use this part, and it would fit. However, I could be mistaken because I made my own rather then buy this one.
Car Meanins:
mykel78
Post by mykel78 »
Yes, it will work on DOHC!!!! I bought one, installed on my 94. The Adaptor plate is not needed. The only mod I made was at the throttle body. I cut about 1 inch of the old rubber intake (it was badly cracked inside the ribbed area, hence the upgrade) for a little room by the battery. When I hooked it up the metal tube rubbed my battery, so I allowed some room. Took about an hour and a half. I could do another in 30 mins.
If not broke - don't fix, modify. If broke - fix it right, and make it better.
