ok i have a 93 mx-3 w/ the 4cyl & 5spd tranny..anytime that the engine is under acceleration, there is a loud whine coming from beneath the hood...sounds similar to the sound of a super charger. as the rpm's climb, the sound gets louder...sounds like a belt being loose, or off center, and rubbing against something.
but the weird thing is, it makes this sound in all gears(accelerating or decellerating), including nuetral. but when i push the clutch pedal in, the sounds gets softer as the rpms' drop...and eventually it is silent once the tach reaches 0 rpm's. I know its not a belt, because i can be cruising down the highway at 60 mph with it whining, but the minute i push the clutch in it begins to fade until it is silent.
my last car was an rx-7, and it made similar sounds when the pilot bearing was going out. sound familiar?
high pitched whine from the tranny?
- DJGypsy
Re: high pitched whine from the tranny?
sounds like gear whine to me...check ur transmission gearbox oil
-Dan
(SOLD) '94 RS, rebuilt B6 DOHC engine & cyl head, ACT clutch, e-bay CAI, 2 1/4" exhaust, wide open resonator w/ stock muffler, H&R springs, Tokico HPs, front strut tower brace, KVR drilled rotors w/ carbon fiber pads, Falken tires, Impostor lightweight wheels, Kenwood & MTX sound.
straights are for fast cars, turns are for fast drivers.
whew, hopefully thats it...not that big of a problem, some Redline should solve that
but, from what i understand its somewhat of a pain to reach the filler hole for the tranny fluid? anyone got any tips and/or tricks?
- The_Great_Tonge
ya my car does the same thing too, i recently changed my clutch and it started to do the whine too, if it is the pilot bearing do i have to drop the tranny to replace it?
to get to the pilot bearing, you have to drop the tranny.
check to make sure you're belts aren't too tight first. too much tension can put a strain on the belt/pullies and create "whine".
"MR." Ashley Fowler
'02 Yamaha Warrior (1700cc)
'94 MX-3 RS-t (BPT)~ sold
cardomain pics
"MR." Ashley Fowler
cardomain pics
i dont think it is a problem with the belts. like i stated in my original post, once the clutch pedal is pressed (engine mechanics seperated from the transmission mechanics) the noise stops. the engine will be in full swing, still running, belts still turning, but the whine is absent. i am correct in my understanding that if it was a problem with the belts...there would be no relation to the clutch, arent i?Originally posted by cre8v mx3:
