protege motor swap?
mx3optidrive
protege motor swap?
Post by mx3optidrive »
I was just wondering what are all the parts from the protege do I need to do this and what parts from my '95 RS do I keep? I am trying to get the DOHC 1.8L 4cyl Protege for the swap around '93 or so.
Shop 506-577-6708
cell 506-381-3503
email danny@jdracing.ca
torpedan
Re: protege motor swap?
Post by torpedan »
For the most part its a strait swap. <p>to keep things easiest and runnign best i would do<p>ecu
wireing harness
tranny
axels
motor
get a new clutch if its a stick<p>Personally try to find a front end clip.. i got one for 750 usd
-torp.
I don't own a Mazda.
atila
Post by atila »
front clip would be a good way of doing it simplify many thing in the swap. I would have gone on that road for my friend mx-3 if i had not had my old pro 1.8 dohc laying around. I just use the engine for the swap the rest his all his stock precidia rs 94 except for intake and exhaust manifold the rest all fit on the engine but it's not straight forward.
cybinpro
Post by cybinpro »
Does anyone have any pics of a protege motor in a MX-3? I'd love to see how it looks and such.<p>-Cybin
Stop the rave.... I wanna get off!
torpedan
Post by torpedan »
Here are a couple of the pics of the swap from my car <p>Image<p>Image<p>Image
-torp.
cybinpro
Post by cybinpro »
Damn it looks like such a nice clean install. No tubes running everywhere and such. The protege motor is also much better looking then the sohc motors. Not to menchen the added 40hp. <p>I bet with proper mods you could get 150hp down to the wheels with a BP motor. That's more then the V6 1.8L and some 2.5L V6 swaps. <p>Add some nitrous and shake well.... <p>-Cybin
torpedan
Post by torpedan »
The motor turbos as well as the b6, its a whole diffrent world though, yes 150 would be easy to get to though.<p>There is a dyno at the dragstrip i goto every night i kinda wanna see what i am putting out before i starting doing a lot of mods.
-torp.
cybinpro
Post by cybinpro »
How well does it drive? Is the power like night and day or just a healthy inprovment?<p>Did you use the same gear shifting rods (The ones going from the shifter to the tranny)<p>Which axles did you use? <p>Which motor mount did you replace?<p>How'd you do the TPS plate?
torpedan
Post by torpedan »
not to night and day but a health step up..<p>As for the rest of the questions EVERYTHING including the wire harness was swapped in from the protege
-torp.
jamario
Post by jamario »
Do you think this swap would fit in a 93 rs?????
IF LIFE DOESN'T OFFER A GAME WORTH PLAYING, THEN INVENT ONE.
torpedan
Post by torpedan »
yup yup
-torp.
