valves ticking
valves ticking
anyone have any luck getting rid of that annoying ticking noise the valves make ?<BR>mine doesn't go away after it's warmed up seems to get louder when i put a load on the engine going up a hill for instance hla going bad maybe ?? any way to replace them <BR>'93 1.6l sohc by the way any advice would be greatly appreciated
Re: valves ticking
i changed my oil and it went away
- Custommx3
- Site Administrator
Re: valves ticking
This has come up several times in the past. Try searchin the archive, Im pretty sure you find your answer there<P>(HAPPY NOW SONICXSTACY?)
Re: valves ticking
thanks guys , sounds like a bunch of squirrels running in a cage under the hood will give it a shot and see how she makes out
Re: valves ticking
if the oil doesn't work, add a bottle of<BR>STP 4 CYLINDER OIL TREATMENT...JUST GO TO ANY AUTOPARTS..IT WORK FOR ME...
TO NOS OR NOT TO NOS? THAT IS THE QUESTION
tinkertank
Re: valves ticking
Try using a thinner oil. Mobil1 5W30 or Mobil1 0W30 will help. Amsoil is better, but harder to find.
MX-3 - 4 cyl. ('92)
tinkertank
Re: valves ticking
<A HREF="http://www.salemboysauto.com/faqs/faq-29.htm" TARGET=_blank>http://www.salemboysauto.com/faqs/faq-29.htm</A>
MX-3 - 4 cyl. ('92)
Re: valves ticking
well tried the engine flush and changing the oil seemed to help a little but still noticeable when putting a load on the engine, any way of checking the hydraulic lash adjusters where do you get them if they are bad ?
Re: valves ticking
try this yellow stuff called risolone. says stops noisy lifters on it. works for me. i use it everytime i change my oil. takes about 50 miles to work in. works for about 2k miles.
<A HREF="http://www.geocities.com/mail_cory_here" TARGET=_blank>Codenes Car</A>
