I WANT A HEADER!!!!!!
Re: I WANT A HEADER!!!!!!
I know I saw a company somewhere that makes a header for the SOHC. I'm a DOHC owner and I was looking for one for my car... all I found was a SOHC. I'll post when I find the company again.<P>
Jordan<BR>1994 White RS
here is a site <A HREF="http://www.festivamotorsport.com/performance/engine.htm" TARGET=_blank>http://www.festivamotorsport.com/perfor ... ine.htm</A> go to bottom there is a header for the b6 sohc planning on buying it since i also have a 92 sohc
let us know if that festiva header fits... thanks. i too am a SOHC rebuilder. i think it is a fine engine for rebuilding and can get plenty of hp from it as well...
1992 White MX3 1.6l SOHC
- For Sale - 105,000 miles / 3,000 miles on engine
- Original B6 Bored 2 Over
- Centerforce Dual Friction Clutch
- Short Shifter
- Cross Drilled and Slotted Rotors
- KYB GR-2 Shocks/Struts
- Steel Braided Front Brake Lines
- Reverse indiglo gauges and carbon fiber trim
- Front and Rear Strut Tower Bars
- 17" Sumitomo Tires on Anthracite/Chrome Loco Wheels
- Short Shifter
Is that Festivia headers better hthan the hurricane header on corksport.com?
IF LIFE DOESN'T OFFER A GAME WORTH PLAYING, THEN INVENT ONE.
OK guys, silly question: WHAT IS A HEADER???
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by ravve:<BR><STRONG>OK guys, silly question: WHAT IS A HEADER???</STRONG><HR></BLOCKQUOTE><P>Exhaust manifold. It's the first piece of your exhaust after the engine.
If you really want somthing cool, go to a hardware store, get some 1 inch piping (or whatever diameter you want), mandrel bend it (they sell those too) and weld ur own, you just hafta keep the origonal flange from your exahaust manifold. Or take the idea to a good shop. The can do it probably for under 300 (US). It shouldn't be too hard! I was thinking about doing it for my DOHC, BUT i'm wanting to swap to the b6t too bad to go the NA route. Well good luck.
16" Sport Edition Fox 2's, Yokohama H4's, Eclipse CD player, Eclipse components, MTX amp, Lightning Audio woofers in a custom fiber glass enclosure, custom intake, factory spoiler installed, reverse indiglo gauges, custom switch panel<p>
www.geocities.com/timsmx3
how the hell you gonna bend your own headers!
for god sakes DONT listen to that idea. Headers are NOT just pipes that lead to your exhaust system. There are certain dynamics, measurements, etc that need to be considered before you even think about fabrication. Unless you've mastered air velocity, flow, length, mass and a handful of other elements dont even bother.
Shaun Newman
