wire connector help!
- mazdaspeed23
Hey guys finally got some time to start putting the dash back together, but I have a problem ( i think). Theres a white connector under the dash on the drivers side its in the harness where the relays are just behind the fuse panel. I cant seem to find anywhere for it to connect to? The wires colours are Green, Green W orange,black,red, white W green
Last edited by mazdaspeed23 on September 11th, 2015, 11:21 am, edited 1 time in total.
Own
1994 MX-3 GS swapped ZE
1994 MX-3 GS Swapped ZE (Gone)
1996 Dodge Dakota Sport v8 Magnum
2007 Ford Fusion SE
WORK LOG: http://mx-3.com/phpBB3/viewtopic.php?f=46&t=81232
![Image](http://i1187.photobucket.com/albums/z397/moneyshot23/rsz_1994155_10152926217650640_511810948_n_zps966fe00a.jpg)
My MX-3 is nothing without me, and i am nothing without my MX-3
2007 Ford Fusion SE
- WhiteFinish
Re: wire connector help!
Picture ? what year car? Is it pre or post facelift
- mazdaspeed23
Sorry its a 94 klze. Pic is here![Image](http://i1187.photobucket.com/albums/z397/moneyshot23/Mobile%20Uploads/IMG_20150910_165109_zpsj0klgp8q.jpg)
Last edited by mazdaspeed23 on September 11th, 2015, 11:22 am, edited 1 time in total.
Own
2007 Ford Fusion SE
2007 Ford Fusion SE
- mazdaspeed23
any idea?
Own
2007 Ford Fusion SE
2007 Ford Fusion SE
- mazdaspeed23
any one?
Own
2007 Ford Fusion SE
2007 Ford Fusion SE
- mazdaspeed23
so I took the dash out and the joint box today, and there is no extra connector for this piece to connect to.
Own
2007 Ford Fusion SE
2007 Ford Fusion SE
- mazdaspeed23
So I finally found out what that connector is for, had to search through my Alldata for a while, but it's the connector for power locks which I don't have in this car.
Own
2007 Ford Fusion SE
2007 Ford Fusion SE
- WhiteFinish
Wires is always looking for a needle in a (mx3) haystack.
- mazdaspeed23
it's crazy. I have heard ample of times that Mazda had the same wiring for the mx3's from its first production car to 93. in 94 they changed some wiring then changed it back to normal in 95. does anyone know what exactly wires were changed? In my all data it shows the exact same wire colour coding as the 95 and 93.
Own
2007 Ford Fusion SE
2007 Ford Fusion SE
- WhiteFinish
If you already found out why the plug is disconnected, what else do you need?
- mazdaspeed23
Nothing. Was just curious to know if anyone knew about the different wires
Own
2007 Ford Fusion SE
2007 Ford Fusion SE
