slimas 1992 1.6 SOHC TURBO MX-3
Re: slimas 1992 1.6 SOHC TURBO MX-3
In order to change my ecu i need 1300USD. In order to change my turbo - i need 100USD. Since this is a budjet project, i'll change my turbo
Mazda MX-3 1992 1.6 SOHC
Damn, forgot to answer to this postSurgeonasst222 wrote:Think u can give a run down on the complete set up on the turbo on this thing... I share the same engine as u I would like to know the details
So here it goes:
Parts taken from the BF Mazda 323 GTX 1.6 DOHC Turbo (B6T engine code):
300cc fuel injectors
ECU
Engine wiring
AFM
TPS sensor
Spark distributor
Knock sensor
Other parts:
Iridium spark plugs
Custom made exhaust manifold
KKK Turbo from a Citroen diesel
Blow off valve
Cone air filter
Boost gauge
And that's about it
