Upstream rear O2 sensor
ZeroLux
Anyone have any good suggestions for trying to replace the rear upstream o2? Just put the MX up on jack stands as high as I could and crawled under. Got a good look at where it's located, cant seem to get any tools to reach it well, lots of exhaust piping in the way.
- mitmaks
Re: Upstream rear O2 sensor
You'll need one of these... special socket for unbolting o2 sensors
http://www.harborfreight.com/3-8-eighth ... 97177.html
ZeroLux
Yeah, I have one of those. It's not a question of the tool, it's a question of placement/lack of elbow room to work with it. I'll probably just take it to a shop tomorrow instead of fighting with it in my garage. Also think I noticed one of the downpipes being loose under there (on the back side), is there a metal covering over that part of the exhaust or have my welds broken just below the joint after the manifold? Seemed to have too much play in it.
- mitmaks
You should be able to get it off with wrench/socket. I just did mine last year
- MrMazda92
Don't take it to a shop unless you've exhausted all other avenues man... It's so costly, for such a simple thing.
It sucks, but you'll manage it... Try a crow-foot or adjustable wrench?
- mitmaks
Remember to use pb blaster to soak it real good, it will be frozen on there from all the heat
- MrMazda92
If you can do it without melting the wires, try a torch too...
Ha, mine was so tight torches, wrenches, cussing, big hammer, nothing nope, nothing would budge it. I said screw this and installed headers.
I'm sure yours won't be that difficult
Good luck.
crazycanadian
I feel sorry for you living in the bad rust belt area...Daninski wrote:Ha, mine was so tight torches, wrenches, cussing, big hammer, nothing nope, nothing would budge it. I said screw this and installed headers.I'm sure yours won't be that difficult
Good luck.
Take about rust belts, being Canadian in Ontario means back bacon, toques, donuts and oxidation. Every year I bring my Dad's scooter to be 'Rust Checked'. My brothers prosthetic leg seized up over night after the first snow last year and I had to use an acetylene torch and penetrate to loosen it up so he could walk to the crapper. Sucks for rust here that's for sure.
