wytbishops endlinks and bushing and what ever else? help
this has got to be the dumbs s@$^ to ask i look one here and i dont see any info on this in detail who is wytbishops and how do i get stuff from him cus i have need of poly bushing, adj endlinks and some other stuff
mazda mx-3 1.6l(first car) ihi vj14 (323gtx turbo) gs suspention soon megasquirt out in indianapolis in
Re: wytbishops endlinks and bushing and what ever else? help
Wytbushings sadly, will never be seen again. I left the mold with the company that poured the parts for me on the last run a nd they have informed me that it is gone.
The adjustable enlinks are easy enough to make yourself although in my opinion OEM is the best option. There is no tangible gain from the end links and they are clicky and expensive.
Most of the bushings are still made by Whiteline. Roughly same prices too.
Black 1993 Mazda MX-3 GS - daily driver
Kenwood BT-948HD, MB Quart FX4.100 and ONX1.1000D, Polk MM6501 x4, Polk MM1240
SE interior, MOMO Endurance shift boot, Tomei long shift knob, eBay short shifter
Red 1987 Toyota MR2 - go kart
"If it's crazy you want, it's crazy you get."
thank you both of you
- onlytrueromeo
Charlie, how hard is it to make the molds? I have not installed my set since I have not worked on my car since I moved :-/.
The mold cost about $2300CAD IIRC. It was machined from aluminum on a 5 axis mill. It could be recreated but the cost is too high and I can't get the interest as it is.
Energy Suspension has control arm bushings for the Escort ZX2. May possibly fit. They're only $26 for a full control arm set).
