Rob's '95 RS -> BP is in!
RobMinhas
Re: Robs '95 RS Daily driver: Got $5,000 in scholarships!!
Do you still park you're car outside Evo?
- Evo_Spec
eyelids aren't install right now =D
RobMinhas
Well I guess if someone happened to break into your house and take your eyelids it'd be a damn shame hahahahah
- Evo_Spec
good luck finding them cause even i don't know where they areRobMinhas wrote:Well I guess if someone happened to break into your house and take your eyelids it'd be a damn shame hahahahah
RobMinhas
Hahah well in that case it looks like i'm out of luck!
- ethand
Haha... well I'm thinking I might have to change over to LEDs then eventually... just not sure about the indicators, as I don't think I can be screwed doing the resistors.... Maybe I should just wait til I have my Altezzas, then do it all... hmmm....
'92 JDM Eunos Presso - Zeke
- Evo_Spec
it's super super easy since most resistor kits come with wire tap connectors, so you don't even have to solder.ethand wrote:Haha... well I'm thinking I might have to change over to LEDs then eventually... just not sure about the indicators, as I don't think I can be screwed doing the resistors.... Maybe I should just wait til I have my Altezzas, then do it all... hmmm....
what's this i see? they're finally done?!?!?? only took about 3 months to get them installed lol
actually rob came over to my place and held the flashlight for me as i "helped" him do it
wish i took pictures of the install as i think i did a pretty nice job but i forgot too
RobMinhas
I came over to Evo's place and watched him wire up my Projectors and HIDs ahaha. He also replaced my spark plug wires, and I swear to god the throttle response is better and the car goes even faster. Performance has gone up maybe 25-35%. It feels insanely different, I have to drive my car differently now hahah.
He did a mighty fine job at it, a very nice setup and they work magnificently. I just need to even out the beams properly, I'm not really sure what I'm doing so I'm gonna try it tomorrow and find a nice place for the beams to hit as they are intersecting at a horrible angle right now. I think if I tighten one side and loosen the opposite side it would move towards the nut I'm tightening, anyone know how that works? And how should the beams properly point out? My guess is that they should be straight out and shouldn't intersect so that the light goes outward straight.
I found this guide but it makes very little sense to me as far directions go. http://www.danielsternlighting.com/tech/aim/aim.html
I'm just gonna park a car twenty feet in front and check the vertical by wether it blinds the other driver or not haha.
But my car bathes the road in light, its wonderful
- Evo_Spec
i'll better your guide with a video.
http://www.youtube.com/watch?v=W9spdW6TiDQ#t=07m00s
- Ryan
For the LED's.... Mx's use a thermal flasher. The power sent to the signals goes through a unit that has a wire in it that heats up and bends, opening the circuit, then cools, bends back, and closes it again. If your draw is too high (resistance too low) then it heats up too fast, and you get the fast flashing.
Look at what wattage the stock bulbs are, and then apply
R=v^2 / P where V is the alternator provided voltage, and P is the bulb wattage.
Then you need to add a resistor of that (R) value. You can neglect the resistance of the LED(or measure it, but its a little difficult), just round down your R value. If its too fast/slow for you, change it out for 1 or 1/2 ohm higher/lower.
If you want a webpage to read.... http://www.kpsec.freeuk.com/components/led.htm
RobMinhas
So i've got a list here that I want to get on top of:
1. Install bolt next to my headlight so my bumper won't fall off.
-Me and Evo forgot to replace them or something, not too sure what happened
2. Get some more zip ties to make sure the wire tuck is proper for the lights(just insurance pretty much)
3. Pull out my day time runner fuse.
4. Pay someone to install my damn remote starter.
-I've had this since october I just didn't get it installed because I wanted to get it installed the same time as my power lock set up(it's a prostart 2in1 keyless entry and remote start, I just need an actuator basically). I have no idea how to do it and it seems ridiculously complicated and risky for an amateur. I'm hoping to get it installed for about $100.
Man oh man, you don't know regret until you sit in your cold car in -30 weather with a brand new remote start system in your back seat that you've had sitting around for three months.
- Ryan
By a shop, look at the prostart installation closer to $400-$500...
RobMinhas
I knowRyan wrote:By a shop, look at the prostart installation closer to $400-$500...
- Evo_Spec
if you can trust his skills i don't see why notRobMinhas wrote:I knowRyan wrote:By a shop, look at the prostart installation closer to $400-$500...I found one a guy who does it at home for about $100 who I'm looking at getting it installed from.
RobMinhas
He seems legit, says he has done them before. I don't personally know anyone who has had them done by him though. I also know a friend of a friend who knows what he's doing and does them for 180. I've seen his handiwork and he seems to be reputable. I think I'll shoot him an email and see who seems more reputable to go to.Evo_Spec wrote:if you can trust his skills i don't see why notRobMinhas wrote:I knowRyan wrote:By a shop, look at the prostart installation closer to $400-$500...I found one a guy who does it at home for about $100 who I'm looking at getting it installed from.
