Fuel Filter Replacement, which filter?
2weeler
Post by 2weeler »
Hey guys pretty simple question regarding fuel filter replacement.
The fuel filter my autoparts store can get for me is either the 91 fuel filter (@ $90) or 92 onwards fuel filter (@ $50).
I obviously would like the cheaper one, can I use the 92 onwards fuel filter on a 91 V6 eunos presso?
Once again sorry for the noob question.
Thanks in advance.
mikeinaus
Re: Fuel Filter Replacement, which filter?
Post by mikeinaus »
pretty sure there all the same. it might have a diffrent mounting bracket but you can figure something out. fyi i just bought a fuel filter for $12 yesterday. id order online if your not in a rush and those are the only prices you can get locally.
2weeler
Post by 2weeler »
Where online did you get it from? I'm not in any rush, its probably been over 10years since it was last replaced. Only problem is I'm from New Zealand ($50NZD is ~$35USD), SO not sure where's the easiest place to order one from.
mitmaks
Post by mitmaks »
check Ebay
BornSticky
Post by BornSticky »
you can use probe or mx6 filter as well just a bit bigger but fits
#5389 to join MX-3.com
