Hey guys pretty simple question regarding fuel filter replacement.
The fuel filter my autoparts store can get for me is either the 91 fuel filter (@ $90) or 92 onwards fuel filter (@ $50).
I obviously would like the cheaper one, can I use the 92 onwards fuel filter on a 91 V6 eunos presso?
Once again sorry for the noob question.
Thanks in advance.
Fuel Filter Replacement, which filter?
mikeinaus
Re: Fuel Filter Replacement, which filter?
pretty sure there all the same. it might have a diffrent mounting bracket but you can figure something out. fyi i just bought a fuel filter for $12 yesterday. id order online if your not in a rush and those are the only prices you can get locally.
Where online did you get it from? I'm not in any rush, its probably been over 10years since it was last replaced. Only problem is I'm from New Zealand ($50NZD is ~$35USD), SO not sure where's the easiest place to order one from.
- mitmaks
check Ebay
- BornSticky
you can use probe or mx6 filter as well just a bit bigger but fits
#5389 to join MX-3.com
