Egr Delete plate
eunosklde
Egr Delete plate
Post by eunosklde »
Hey crew,I Got a 92 mazda mx3,2002 longneck Klde running a KL31 ecu,Can't seem to get my vris in check.The thing is i was thinking of installing a EGR DELETE plate from ebay.Will it work on my setup and is it worth it and is there much hp gain.Thanx for any info :)
cWs306
Re: Egr Delete plate
Post by cWs306 »
hmm, there's an EGR on a KLDE? hmm must just be the ZE that doesnt have one. but yes, egr's usually kill some power. best way to fill the hole from it is to get a plug that u can screw into the block. like a Allen key type plug. and it would only cost like 2 bucks. and less waiting. but you gotta tap your block. thats not always fun. but then u take the coolant line coming from the head that goes to the EGR and run it straight to the Throttle body from the head.
PATDIESEL
Post by PATDIESEL »
The EGR plate should be oval in shape and have two bolts, on opposite ends. Then, yes, you are going to have to run the collant line straight to the TB. You will also have to plug up the sopt where the EGR goes into the exhaust. The block-off plate does not need to be a allen type screw and there does not need to be any tapping of the block. The stock ZE uses a blok-off plate straight from Mazda and is described as above ;)
eunosklde wrote:Hey crew,I Got a 92 mazda mx3,2002 longneck Klde running a KL31 ecu,Can't seem to get my vris in check.The thing is i was thinking of installing a EGR DELETE plate from ebay.Will it work on my setup and is it worth it and is there much hp gain.Thanx for any info :)
Not sure here but how does one relate to the other and do you want help with your VRIS? Let us know what RPM your VRIS is actuating at now.
mikeinaus
Post by mikeinaus »
PATDIESEL wrote:The EGR plate should be oval in shape and have two bolts, on opposite ends. Then, yes, you are going to have to run the collant line straight to the TB. You will also have to plug up the sopt where the EGR goes into the exhaust. The block-off plate does not need to be a allen type screw and there does not need to be any tapping of the block. The stock ZE uses a blok-off plate straight from Mazda and is described as above ;)
sorry to thread jack. does the klze have a egr block off plate? i was under the impression there was no hole in the block and that it would have to be drilled out to fit an egr valve?
cWs306
Post by cWs306 »
There is no blocking plate on a KLZE. its completely skipped over. your right. you would have to drill it out. but why would anyone want a EGR? they really got no tremendous purpose..
Ryan
Post by Ryan »
EGR helps emissions, overall engine health, combustion temps, fuel mileage....
Its just a fad to delete it. Aside from the valve always going, its a good system to keep. It closes under WOT, so it doesn't hurt your performance, regardless of what anyone says... go read the F2 section in the manual.
I removed it simply for bay cleanliness.
cWs306
Post by cWs306 »
Seriously? it does all that? oh my ahaha. but yah i think it looks better without that extra hunk of metal/hoses there. and specially if you got a CAI..
MrMazda92
Post by MrMazda92 »
I'm deleting it for bay cleanliness and so I don't have to clean my IM out like this again. That alone justifies any "losses" elsewhere.
