Help me tune my ZE.
Re: Help me tune my ZE.
I think the K8 manifold and that ECU are the culprit. Yes knock sensor makes it go into limp mode.
When I replaced my knock sensor I remember removing the intake manifold and the pipe in the middle of the engine. I did not have to remove the colant housing tho. I had to use tiny 10mm wrenches and carefully remove the bolts.
The sensor was rusted, I made an o2 socket; i think 17mm or so. I cut it with a grinder on the side and walla it came out. New sensor from autozone, I bought the probe gt sensor because for some stupid reason its cheaper than the k8 sensor... :/ its the SAME thing same voltage and all...
If the knock sensor code is there replace it. GET RID OF THE K8 MANIFOLD.
I had shitty gas mileage when I had the k8 ecu and k8 manifold on my ze.. not to mention it was WAY slower. Millenia curved neck and kl31/ kl36 ecu ftw.
-hec
so I got 26mpg on the last tank. not as bad as I thought.
mostly highway miles tho![Sad :(](./images/smilies/icon_sad.gif)
what kind of car IS that?
so I really don't have the money to fix all this crap. ugh. this things my only form of transportation. ![Sad :(](./images/smilies/icon_sad.gif)
if i put my k8 injectors on it as is will I get better gas mileage and not kill it if im not pulling off redline touching shifts?
this sounds pretty stupid to me, but I'm wondering if anyone's tried it.
Well, ironing out a motor swap cost money. Should of stuck with the K8 if you can't budget in fixing your ZE to run right. I had a buddy with a Lexus, had to sell it as-is cause he didn't want (or couldn't afford) to replace the $400 (or $175 in the US) ABS sensor, so he took a $4000 hit on the market value of the car...greenstorm wrote:so I really don't have the money to fix all this crap. ugh. this things my only form of transportation.
I don't think anyone had tried it, but really, what would be the point? I could see the ECU being more happy, kinda, but it's probably going to get confused as why the VAF is saying that the motor is pulling in 2500cc of air instead of 1800, if it will read that properly. I just hope it just doesn't run lean on you and cause damage, especially at WOT, hoping that the ECU and the 02's are smart enough to compensate....or if those 180cc injectors can keep up, unless you burn them out running them at 100% duty cycle often.
I suggest you do a [WTB] curved neck ZE (millenia) manifold and see if anyone offers one up at a reasonable price.
- Ryan
ZE manifolds are like the plague on PT. KLG4 will suit you too. only 50ish RPM off of the DE VRIS points.
yeah, I'd better not try it. It was my project car for awhile, when I could afford to put money into it, I'd finish it and drive it...
but things happen and now this is my only mode of transportation. The economy sucks and my BS degree isn't worth s--- now. ugh.
I can't even afford to swap the friggin knock sensors because I'd have to get an o2 socket and an IM gasket. life is tough sometimes.
anyone want to trade me a econo beater for this project? lol jk. I'm venting a bit. Thanks for all the help, everyone.
- Ryan
You can make the socket with a grinder, and you don't need to replace the I/M gasket....
Yeah, I think I'm going to have to. I've tried every tool known to man, and the people at the auto parts store looked at me like "I don't think that part is supposed to be removed"
I have an old knock sensor in the old engine that is laying in my garage. Can't move it at all. Do you remember what size socket you made? It has to be bigger than the O2....which is what... 21mm? I'll have to buy a long socket just for this.
Every stupid thing on this car infuriates me. Can't they make ONE THING SIMPLE?
- Ryan
IIRC its 15/16.
and a KLG4 is a 2002+ 626 engine with coil packs, a special manifold, perhaps special pistons, lightweight crank, and KL01 cams. Makes 170 hp.
No way that's 15/16, lol. It must be a different one than mine? (92)
O2 is 7/8" and that one doesn't fit on. thats like...22?
I wonder if there is a special mazda tool.....
Why can't they just make things simple?
- MrMazda92
They want you to take it to a dealership.greenstorm wrote:I wonder if there is a special mazda tool.....
I have dreams where I'm staring at something stupid like this and just cursing up a storm and throwing tools around.
And when I look behind me, theres 100 mazda engineers laughing at me out loud and giving each other high fives.
- MrMazda92
For every 100 Mazda Engineers, 3 are really Porschegreenstorm wrote:I have dreams where I'm staring at something stupid like this and just cursing up a storm and throwing tools around.
